查看: 2053|回复: 3
[公告]:.NET在AutoCAD 2008中支持自定义实体!!
发表于 2006-10-22 12:10:29 | 显示全部楼层 |阅读模式
刚从一个朋友那里拿到了AutoCAD 2008中有关.NET 开发的4个dll文件,大致看了一下。发现新增加了一个命名空间:Autodesk.AutoCAD.ComponentModel,应该是有关自定义实体的.
下面是这个命名空间中的类:
namespace Autodesk.AutoCAD.ComponentModel
      public interface IPropertyProvider
            // Methods
            PropertyDescriptorCollection GetProperties(object instance);
      public interface ITypeDescriptor
            // Methods
            void AddPerInstancePropertyProvider(IPropertyProvider pp);
            void AddProperty(PropertyDescriptor prop);
            ReadOnlyCollection<IPropertyProvider> GetPerInstancePropertyProviders();
            PropertyDescriptorCollection ModifyPropertyCollection(PropertyDescriptorCollection defaultProps, object instance);
            void RemovePerInstancePropertyProvider(IPropertyProvider pp);
            void RemoveProperty(PropertyDescriptor prop);
            // Properties
            bool HasPerInstancePropertyProviders { get; }
      public abstract class PropertyDescriptorBase<TComponent, TPropertyValue> : PropertyDescriptor
            // Methods
            public PropertyDescriptorBase(string name);
            public PropertyDescriptorBase(string name, Attribute[] att);
            public override bool CanResetValue(object component);
            public override void ResetValue(object component);
            public override bool ShouldSerializeValue(object component);
            // Properties
            public override Type ComponentType { get; }
            public override string DisplayName { get; }
            public override bool IsReadOnly { get; }
            public override Type PropertyType { get; }
      [AttributeUsage(4)]
      public class PropertyProviderAttribute : Attribute
            // Methods
            public PropertyProviderAttribute(Type type);
            // Properties
            public Type PropertyProviderType { get; }
      public class TypeDescriptionProvider<T> : TypeDescriptionProvider
            // Methods
            public TypeDescriptionProvider();
            public override ICustomTypeDescriptor GetTypeDescriptor(Type objectType, object instance);
      public class TypeDescriptor : ITypeDescriptor
            // Methods
            public TypeDescriptor(Type type);
            public void AddPerInstancePropertyProvider(IPropertyProvider pp);
            public void AddProperty(PropertyDescriptor prop);
            public ReadOnlyCollection<IPropertyProvider> GetPerInstancePropertyProviders();
            public PropertyDescriptorCollection ModifyPropertyCollection(PropertyDescriptorCollection defaultProps, object instance);
            public void RemovePerInstancePropertyProvider(IPropertyProvider pp);
            public void RemoveProperty(PropertyDescriptor prop);
            // Properties
            public bool HasPerInstancePropertyProviders { get; }
      public class TypeManager
            // Properties
            public static TypeManager Instance { get; }
            public ITypeDescriptor this[Type type] { get; }
发表于 2006-10-22 18:17:49 | 显示全部楼层
明显是替换COM功能的几个接口,从AutoCAD2005->2006->2007的.NET API发展历程看,我不太觉得在这个版本会完全实现。
现在使用R14的工程师还多得不得了,就算ADESK在.NET上实现了自定义实体,也只能供不多的几个程序员意淫而已。
 楼主| 发表于 2006-10-22 18:41:06 | 显示全部楼层
最初由 masterhe 发布
[B]明显是替换COM功能的几个接口,从AutoCAD2005->2006->2007的.NET API发展历程看,我不太觉得在这个版本会完全实现。
现在使用R14的工程师还多得不得了,就算ADESK在.NET上实现了自定义实体,也只能供不多的几个程序... [/B]
使用R14的还有几个?!你的多的不得了,也估计是意淫罢了。
发表于 2006-10-22 19:50:01 | 显示全部楼层
看来简单的文字,让人阅读后不产生误解也挺难的,怪不得现在不少人洋文不错,中文很差。
不过倒是可以给你透露一下,我每年会专程循环去国内的各大城市拜访老用户,取得第一手的使用情况,有些数据不是那些简单将Autodesk.AutoCAD.DatabaseServices.Line作个所谓“封装”的人所能明白的。
GMT+8, 2026-11-22 07:59 , Processed in 0.583958 second(s), 16 queries , Gzip On, File On.
