查看: 2294|回复: 0
[转贴]:VBA_选择集增强类(TlsSelectionSet)
发表于 2007-2-14 15:00:45 | 显示全部楼层 |阅读模式
[PHP]Private oSel As AcadSelectionSet
Private m_Filter As New TlsResultBuffer
Private sName As String
Private bDeleted As Boolean
Private Function IsNull() As Boolean
If oSel Is Nothing Then
IsNull = True
ElseIf oSel.Count = 0 Then
IsNull = True
Else
IsNull = False
End If
End Function
Public Sub Init(Optional ByVal Name As String = "TlsSelectionSet", Optional ClearFilter As Boolean = True, Optional Deleted As Boolean = True)
'创建选择集
On Error Resume Next
If ClearFilter Then m_Filter.Clear
bDeleted = Deleted
If Not oSel Is Nothing Then oSel.Delete
sName = Name
ThisDrawing.SelectionSets(sName).Delete
Set oSel = ThisDrawing.SelectionSets.Add(sName)
End Sub
Private Sub Class_Terminate()
'类析构时清除选择集
If bDeleted Then oSel.Delete
End Sub
Public Function ToArray()
'转化选择集为对象数组输出
Dim i
Dim objs() As AcadEntity
Dim nCount As Integer
nCount = oSel.Count - 1
ReDim objs(nCount)
For i = 0 To nCount
Set objs(i) = oSel(i)
Next i
ToArray = objs
End Function
Public Property Get Count() As Integer
'获取选择集实体个数
Count = oSel.Count
End Property
Public Property Get Name() As String
'获取选择集名称
Name = sName
End Property
Public Property Get Item(ByVal Index) As AcadEntity
'获取选择集实体
Set Item = oSel(Index)
End Property
Public Property Get Deleted() As Boolean
Deleted = bDeleted
End Property
Public Property Let Deleted(ByVal Value As Boolean)
bDeleted = Value
End Property
Public Property Get AcSet() As Variant
'获取选择集
Set AcSet = oSel
End Property
Public Property Set AcSet(Value As Variant)
'获取选择集
Set oSel = Value
End Property
Public Sub AddItems(ByVal objs)
'向选择集加入实体
If IsArray(objs) Then
oSel.AddItems objs
ElseIf IsObject(objs) Then
If TypeOf objs Is AcadSelectionSet Then
Dim temp As New TlsSelectionSet
temp.Deleted = False
temp.AcSet = objs
oSel.AddItems temp.ToArray
ElseIf TypeOf objs Is TlsSelectionSet Then
oSel.AddItems objs.ToArray
Else
Dim ents(0) As AcadEntity
Set ents(0) = objs
oSel.AddItems ents
End If
End If
End Sub
Public Sub RemoveItems(ByVal objs)
'在选择集中移除实体
oSel.RemoveItems objs
temp.AcSet = objs
oSel.RemoveItems temp.ToArray
oSel.RemoveItems objs.ToArray
Else
Set ents(0) = objs
oSel.RemoveItems ents
End If
End If
End Sub
Public Sub Clear()
'清空选择集
Init sName
oSel.Clear
End Sub
Public Sub Update()
oSel.Update
End Sub
Public Property Get PickfirstSelectionSet() As AcadSelectionSet
'获取Pickfirst选择集
ThisDrawing.SelectionSets("PICKFIRST").Delete
Set PickfirstSelectionSet = ThisDrawing.PickfirstSelectionSet
End Property
Public Property Get ActiveSelectionSet() As AcadSelectionSet
'获取Active选择集
ThisDrawing.SelectionSets("CURRENT").Delete
Set ActiveSelectionSet = ThisDrawing.ActiveSelectionSet
End Property
Public Sub SelectOnScreen()
If m_Filter.IsNull Then
oSel.SelectOnScreen
Else
oSel.SelectOnScreen m_Filter.TypeCodes, m_Filter.Datas
End If
End Sub
Public Sub SelectSingleObject()
On Error GoTo ErrHandle
Dim obj As AcadEntity, pnt
SelectObject acSelectionSetAll
Do
ThisDrawing.Utility.GetEntity obj, pnt
oCount = Count
RemoveItems obj
If oCount <> Count Then
Clear
AddItems obj
Exit Do
End If
Loop
Exit Sub
ErrHandle:
Clear
End Sub
Public Sub SelectObject(ByVal Mode As AcSelect, Optional ByVal Point1, Optional ByVal Point2)
If IsMissing(Point1) Then
oSel.Select Mode
Else
oSel.Select Mode, Point1, Point2
End If
Else
oSel.Select Mode, , , m_Filter.TypeCodes, m_Filter.Datas
Else
oSel.Select Mode, Point1, Point2, m_Filter.TypeCodes, m_Filter.Datas
End If
End If
End Sub
Public Sub SelectAtPoint(ByVal Point)
oSel.SelectAtPoint Point
Else
oSel.SelectAtPoint Point, m_Filter.TypeCodes, m_Filter.Datas
End If
End Sub
Public Sub SelectByPolygon(ByVal Mode As AcSelect, Optional ByVal Points)
oSel.SelectByPolygon Mode, Points
Else
oSel.SelectByPolygon Mode, Points, m_Filter.TypeCodes, m_Filter.Datas
End If
End Sub
Public Property Let Visible(ByVal Value As Boolean)
If IsNull() Then Exit Property
Dim i As AcadEntity
For Each i In oSel
i.Visible = Value
Next i
End Property
Public Property Let Layer(ByVal Value As String)
Dim i As AcadEntity
For Each i In oSel
i.Layer = Value
Next i
End Property
Public Property Let LineType(ByVal Value As String)
Dim i As AcadEntity
For Each i In oSel
i.LineType = Value
Next i
End Property
Public Property Let Color(ByVal Value As ACAD_COLOR)
Dim i As AcadEntity
For Each i In oSel
i.Color = Value
Next i
End Property
Public Sub Move(Optional ByVal Point1, Optional ByVal Point2)
If IsNull() Then Exit Sub
If IsMissing(Point1) Then Point1 = CreatePoint()
If IsMissing(Point2) Then Point2 = CreatePoint()
Dim i As AcadEntity
For Each i In oSel
i.Move Point1, Point2
Next i
End Sub
Public Function Copy(Optional ByVal Point1, Optional ByVal Point2)
Dim i
ReDim objs(Count - 1)
For i = 0 To Count
Set objs(i) = oSel(i).Copy
objs(i).Move Point1, Point2
Next i
Copy = objs
End Function
Public Sub Rotate(Optional ByVal BasePoint, Optional ByVal RotationAngle As Double = 1#)
If IsMissing(BasePoint) Then BasePoint = CreatePoint()
Dim i As AcadEntity
For Each i In oSel
i.Rotate BasePoint, RotationAngle
Next i
End Sub
Public Sub Rotate3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal RotationAngle As Double = 1#)
Dim i As AcadEntity
For Each i In oSel
i.Rotate3D Point1, Point2, RotationAngle
Next i
End Sub
Public Sub ScaleAll(Optional ByVal BasePoint, Optional ByVal ScaleFactor As Double = 1)
Dim i As AcadEntity
For Each i In oSel
i.ScaleEntity BasePoint, ScaleFactor
Next i
End Sub
Public Sub Mirror(Optional ByVal Point1, Optional ByVal Point2)
Dim i As AcadEntity
For Each i In oSel
i.Mirror Point1, Point2
Next i
End Sub
Public Sub Mirror3D(Optional ByVal Point1, Optional ByVal Point2, Optional ByVal Point3)
If IsMissing(Point3) Then Point3 = CreatePoint()
Dim i As AcadEntity
For Each i In oSel
i.Mirror3D Point1, Point2, Point3
Next i
End Sub
Public Sub Highlight(Optional ByVal HighlightFlag As Boolean = True)
Dim i As AcadEntity
For Each i In oSel
i.Highlight HighlightFlag
Next i
End Sub
Public Sub Delete()
oSel.Erase
End Sub
Public Sub CopyObjects(Optional ByVal Owner, Optional ByVal IdPairs)
If IsMissing(Owner) Then
If IsMissing(IdPairs) Then
ThisDrawing.CopyObjects ToArray
Else
ThisDrawing.CopyObjects ToArray, , IdPairs
End If
Else
ThisDrawing.CopyObjects ToArray, Owner
Else
ThisDrawing.CopyObjects ToArray, Owner, IdPairs
End If
End If
End Sub
Public Sub GetBoundingBox(ByRef MinPoint, ByRef MaxPoint)
Dim i
Dim d1, d2, p1, p2
oSel(0).GetBoundingBox d1, d2
For i = 1 To Count - 1
oSel(i).GetBoundingBox p1, p2
If p1(0) < d1(0) Then d1(0) = p1(0)
If p1(1) < d1(1) Then d1(1) = p1(1)
If p2(0) > d2(0) Then d2(0) = p2(0)
If p2(1) > d2(1) Then d2(1) = p2(1)
Next i
MinPoint = d1
MaxPoint = d2
End Sub
Public Function CreatePoint(Optional ByVal X As Double = 0#, Optional ByVal Y As Double = 0#, Optional ByVal Z As Double = 0#)
Dim pnt(2) As Double
pnt(0) = X: pnt(1) = Y: pnt(2) = Z
CreatePoint = pnt
End Function
Public Function ToBlock(Optional ByVal InsertionPoint, Optional ByVal Name As String = "*U") As String
If IsMissing(InsertionPoint) Then InsertionPoint = CreatePoint()
If IsNull() Then Exit Function
Dim oBlock As AcadBlock
Set oBlock = ThisDrawing.Blocks.Add(InsertionPoint, Name)
CopyObjects oBlock
ToBlock = oBlock.Name
ErrHandle:
End Function
Public Property Get Filter() As TlsResultBuffer
Set Filter = m_Filter
If Err Then
Set m_Filter = New TlsResultBuffer
Err.Clear
End If
End Property
[/PHP]
GMT+8, 2026-11-22 07:51 , Processed in 0.198350 second(s), 10 queries , Gzip On, File On.
