查看: 2040|回复: 0
[分享] Circle tangents
发表于 2014-6-7 01:30:19 | 显示全部楼层 |阅读模式
    using System;
    using Autodesk.AutoCAD.Geometry;
    namespace GeometryExtensions
       /// <summary>
       /// Tangent type enum
       /// </summary>
       [Flags]
       public enum TangentType { Inner = 1, Outer = 2 }
       /// <summary>
       /// Provides extension methods for the CircularArc3d class.
       /// </summary>
       public static class CircularArc3dExtensions
           /// <summary>
           /// Returns the tangents between the active CircularArc3d instance complete circle and another one.
           /// </summary>
           /// <remarks>
           /// Tangents start points are on the object to which this method applies, end points on the one passed as argument.
           /// Tangents are always returned in the same order: outer tangents before inner tangents, and for both,
           /// the tangent on the left side of the line from this circular arc center to the other one before the one on the right side.
           /// </remarks>
           /// <param name="arc">The object to which this method applies.</param>
           /// <param name="other">The CircularArc3d to which searched for tangents.</param>
           /// <param name="flags">An enum value specifying which type of tangent is returned.</param>
           /// <returns>An array of LineSegment3d representing the tangents (maybe 2 or 4) or null if there is none.</returns>
           /// <exception cref="Autodesk.AutoCAD.Runtime.exception">eNonCoplanarGeometry is thrown if the objects do not lies on the same plane.</exception>
           public static LineSegment3d[] GetTangentsTo(this CircularArc3d arc, CircularArc3d other, TangentType flags)
               // check if circles lies on the same plane
               Vector3d normal = arc.Normal;
               double elev1 = arc.Center.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
               double elev2 = other.Center.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
               if (!(normal.IsParallelTo(other.Normal) &&
                   Math.Abs(elev1 - elev2) < Tolerance.Global.EqualPoint))
                   throw new Autodesk.AutoCAD.Runtime.Exception(
                       Autodesk.AutoCAD.Runtime.ErrorStatus.NonCoplanarGeometry);
               // check if a circle is inside the other
               double dist = arc.Center.DistanceTo(other.Center);
               if (dist - Math.Abs(arc.Radius - other.Radius) <= Tolerance.Global.EqualPoint)
                   return null;
               // check if circles overlap
               bool overlap = arc.Radius + other.Radius >= dist;
               if (overlap && flags == TangentType.Inner)
                   return null;
               CircularArc3d tmp1, tmp2;
               Point3d[] inters;
               Vector3d vec1, vec2, vec = other.Center - arc.Center;
               int i, j;
               LineSegment3d[] result = new LineSegment3d[(int)flags == 3 && !overlap ? 4 : 2];
               // outer tangents
               if (flags.HasFlag(TangentType.Outer))
                   if (arc.Radius == other.Radius)
                       Line3d perp = new Line3d(arc.Center, vec.CrossProduct(normal));
                       inters = arc.IntersectWith(perp);
                       vec1 = (inters[0] - arc.Center).GetNormal();
                       vec2 = (inters[1] - arc.Center).GetNormal();
                       i = vec.GetAngleTo(vec1, normal) < vec.GetAngleTo(vec2, normal) ? 0 : 1;
                       j = i ^ 1;
                       result[i] = new LineSegment3d(inters[0], inters[0] + vec);
                       result[j] = new LineSegment3d(inters[1], inters[1] + vec);
                   else
                       Point3d center = arc.Radius < other.Radius ? other.Center : arc.Center;
                       tmp1 = new CircularArc3d(center, normal, Math.Abs(arc.Radius - other.Radius));
                       tmp2 = new CircularArc3d(arc.Center + vec / 2.0, normal, dist / 2.0);
                       inters = tmp1.IntersectWith(tmp2);
                       vec1 = (inters[0] - center).GetNormal();
                       vec2 = (inters[1] - center).GetNormal();
                       j = i ^ 1;
                       result[i] = new LineSegment3d(arc.Center + vec1 * arc.Radius, other.Center + vec1 * other.Radius);
                       result[j] = new LineSegment3d(arc.Center + vec2 * arc.Radius, other.Center + vec2 * other.Radius);
               // inner tangents
               if (flags.HasFlag(TangentType.Inner) && !overlap)
                   double ratio = (arc.Radius / (arc.Radius + other.Radius)) / 2.0;
                   tmp1 = new CircularArc3d(arc.Center + vec * ratio, normal, dist * ratio);
                   inters = arc.IntersectWith(tmp1);
                   i = vec.GetAngleTo(vec1, normal) < vec.GetAngleTo(vec2, normal) ? 2 : 3;
                   j = i == 2 ? 3 : 2;
                   result[i] = new LineSegment3d(arc.Center + vec1 * arc.Radius, other.Center + vec1.Negate() * other.Radius);
                   result[j] = new LineSegment3d(arc.Center + vec2 * arc.Radius, other.Center + vec2.Negate() * other.Radius);
               return result;
           /// <summary>
           /// Returns the tangents between the active CircularArc3d instance complete circle and a point.
           /// </summary>
           /// <remarks>
           /// Tangents start points are on the object to which this method applies, end points on the point passed as argument.
           /// Tangents are always returned in the same order: the tangent on the left side of the line from the circular arc center
           /// to the point before the one on the right side.
           /// </remarks>
           /// <param name="pt">The Point3d to which tangents are searched</param>
           /// <returns>An array of LineSegement3d representing the tangents (2) or null if there is none.</returns>
           public static LineSegment3d[] GetTangentsTo(this CircularArc3d arc, Point3d pt)
               // check if circle and point lies on the plane
               double elev2 = pt.TransformBy(Matrix3d.WorldToPlane(normal)).Z;
               if (Math.Abs(elev1 - elev2) < Tolerance.Global.EqualPoint)
               // check if the point is inside the circle
               Point3d center = arc.Center;
               if (pt.DistanceTo(center) <= arc.Radius)
                   return null;
               Vector3d vec = pt.GetVectorTo(center) / 2.0;
               CircularArc3d tmp = new CircularArc3d(pt + vec, arc.Normal, vec.Length);
               Point3d[] inters = arc.IntersectWith(tmp);
               LineSegment3d[] result = new LineSegment3d[2];
               int i = vec.GetAngleTo(inters[0] - center, normal) < vec.GetAngleTo(inters[1] - center, normal) ? 0 : 1;
               int j = i ^ 1;
               result[i] = new LineSegment3d(inters[0], pt);
               result[j] = new LineSegment3d(inters[1], pt);
               return result;
GMT+8, 2026-11-22 07:58 , Processed in 0.555887 second(s), 10 queries , Gzip On, File On.
