查看: 854|回复: 1
[求助] [求助]:action函数限制字符串长度吗?
发表于 2003-6-3 22:19:32 | 显示全部楼层 |阅读模式
下面这个程序我加载后总是出现“输入字符串太长”的错误!!
请高手指点
(defun C:dangqiang( / dcl_id linshi h)
  (setq dcl_id (load_dialog "dangqiang.dcl"))                ;加载 DCL 文件
  (if (not (new_dialog "dangqiang" dcl_id))                        ;初始化对话框
    (exit)                                                        ;如果不工作就退出
  (setq x (dimx_tile "img")
      y (dimy_tile "img"))
(start_image "img")
( slide_image 0 0 x y "dangqiang")
(end_image)
  (set_tile "qiangyou" "2000")
  (set_tile "qiangzuo" "1000")
  (set_tile "qianghou" "200")
  (set_tile "qiangzhi" "200")
  (set_tile "rongzhong" "20")
  (set_tile "duizai" "10")
  (set_tile "langken" "0.3333333333")
  (set_tile "jianju" "200")
  (action_tile "cal" "(setq linshi (atof (get_tile \"ziyou\")))
      (setq Y (atof (get_tile \"rongzhong\")))
      (setq Q (atof (get_tile \"duizai\")))
      (setq l (atof (get_tile \"langken\")))
      (setq C (atof (get_tile \"tong\")))
      (if (= C 0) (setq c 9.6) (if (= C 1) (setq c 11.9) (if (= C 2) (setq c 14.3) (if (= C 3) (setq c 16.7) (setq c 19.1)))))
      (if (= c 9.6) (setq t \"C20\") (if (= c 11.9) (setq t \"C25\") (if (= c 14.3) (setq t \"C30\") (if (= c 16.7) (setq t \"C35\") (setq t \"C40\")))))
      (setq F (atof (get_tile \"gangjin\")))
      (if (= F 0) (setq f \"HPB235\") (if (= F 1) (setq f \"HRB335\") (if (= F 2) (setq f \"HRB400\") (setq f \"RRB400\"))))
      (setq J (atof (get_tile \"jianju\")))
      (setq D (atof (get_tile \"qiangzhi\")))
      (setq H (atof (get_tile \"qiangyou\")))
      (setq lb \"---------------------------挡墙计算书--------------------------------\")
      (setq b (write-line lb (open \"C:/test.txt\" \"w\")))
      (open \"C:/test.txt\" \"a\")
      (if (= linshi 0) (setq lb \"挡墙顶部为简支\") (setq lb \"挡墙顶部为自由\"))
      (setq b (write-line lb (open \"C:/test.txt\" \"a\")))
      (setq lb (strcat \"挡墙右边的回填土高度为\" (rtos H) \"mm\"))
      (setq Z (atof (get_tile \"qiangzuo\")))
      (setq lb (strcat \"挡墙左边的回填土高度为\" (rtos Z) \"mm\"))
      (setq B (atof (get_tile \"qianghou\")))
      (setq lb (strcat \"挡墙墙体的厚度为\" (rtos B) \"mm\"))
      (setq lb (strcat \"墙趾的厚度为\" (rtos D) \"mm\"))
      (setq lb (strcat \"回填土的容重为\" (rtos Y) \"kN/m^3\"))
      (setq lb (strcat \"右侧回填地面有堆载\" (rtos Q) \"kN/m^2\"))
      (setq lb (strcat \"郎肯系数取为\" (rtos l)))
      (setq lb (strcat \"混凝土强度等级\" t))
      (setq lb (strcat \"钢筋强度等级\" f))
      (setq lb (strcat \"钢筋的主筋间距为\" (rtos J) \"mm\"))
      (startapp \"notepad\" \"C:/test.txt\")"
  (action_tile "cancel" "(done_dialog 0)")  ;卸载 DCL 件
  (start_dialog)     ;显框
  (princ)
  k
是不是我ACTION后的操作的语句写的太多了,如果不这样还有什么更好的办法么,
我想让KEY被ACTION之后,在C:\test.txt,作为计算书,请高手帮忙
发表于 2003-6-3 22:47:29 | 显示全部楼层
你引用一个内部函数不就结了?
GMT+8, 2026-11-3 19:09 , Processed in 0.639949 second(s), 34 queries , Gzip On.
