查看: 1238|回复: 2
[LISP程序]:切换到物体所在layer 的程序
发表于 2006-11-24 14:20:53 | 显示全部楼层 |阅读模式
(DEFUN C:er(/ VAR1 VAR2 O A P Q)  ;功能:切换到物体所在layer   (SETQ VAR1 (GETVAR "BLIPMODE"))
  (SETQ VAR2 (GETVAR "CMDECHO"))
  (SETVAR "BLIPMODE" 0)
  (SETVAR "CMDECHO"  0)
  (PRINC "\n 切换到物体所在layer  : ")
  (SETQ O (ENTSEL))
  (SETQ A (ENTGET (CAR O)))
  (SETQ P (CDR (ASSOC 8 A)))
  (SETQ Q (GETVAR "CLAYER"))
  (IF (= Q P)
      (PRINC "\n CORRENT LAYER,CAN'T FROOZEN!!!!")
      (COMMAND "_-LAYER" "_s" P "")
  (SETVAR "BLIPMODE" VAR1)
  (SETVAR "CMDECHO"  VAR2)
  (PRINC "\nOK!")(PRINC)
个人感觉很实用,不知道对大家有没有用,支持的顶一下,我将上传更多的的实用的lisp程序源代码!
也希望能给我加点分!
发表于 2007-1-20 14:24:00 | 显示全部楼层
不错,谢谢
已领礼包: 35个
发表于 2009-5-31 13:46:48 | 显示全部楼层
这CAD里就有了
GMT+8, 2026-11-3 09:59 , Processed in 0.476213 second(s), 36 queries , Gzip On.
