查看: 893|回复: 0
[LISP程序]:自动统计不同直径圆数量 ssc
发表于 2006-11-25 21:35:21 | 显示全部楼层 |阅读模式
(defun c:ssc ()
  (setq        Dia (getreal "\n>>直徑: ")
        Rad (/ Dia 2)
  (setq ssRad (ssget "all" (list '(0 . "circle") (cons 40 Rad))))
  (setq num1 (sslength ssRad))
(alert (strcat "直徑" (rtos dia 2 4) "的數量=" (rtos num1 2 4)))
GMT+8, 2026-11-23 16:50 , Processed in 0.249861 second(s), 10 queries , Gzip On, File On.
