查看: 4190|回复: 23
[LISP程序]:光标放在对象上,自动显示对象属性.
发表于 2006-11-30 10:29:27 | 显示全部楼层 |阅读模式
转一个光标放在对象上,自动显示对象属性的LISP程序.命令AAAA
发表于 2006-11-30 12:40:10 | 显示全部楼层
下载 不了。请楼猪检查。
发表于 2006-11-30 18:47:51 | 显示全部楼层
另存就可以呀,我就下载了
发表于 2006-12-1 07:42:47 | 显示全部楼层
下载后将文件扩展名改为.lsp就可以用了!
发表于 2006-12-1 10:18:04 | 显示全部楼层
我移了 好多遍,啥玩意都没显示。
 楼主| 发表于 2006-12-1 14:13:31 | 显示全部楼层
如果下载不了我把代码贴在下面,我用的是2004版的
************************aaaa动态查询**************************
(defun C:aaaa(/ myerr dxf toang fx add_solid add_text dis olderr oldos
oldfill ss pd gr pt ent entold)
(defun myerr(msg)
(setq *error* olderr)
(command "_.undo" "_b")
(princ)
(defun dxf(ent i)
(if (= (type ent) 'ename)
(setq ent (entget ent))
(cdr (assoc i ent))
(defun toang(ang i)
(if (= i 1)
(* ang (/ 180 pi))
(* ang (/ pi 180))
(defun fx(ang)
(cond
((>= (/ pi 2) ang 0) (list pi (+ pi (/ pi 2)) 1))
((>= pi ang (/ pi 2)) (list 0 (+ pi (/ pi 2)) 1))
((>= (+ pi (/ pi 2)) ang pi) (list 0 (/ pi 2) 0))
((>= (* 2 pi) ang (+ pi (/ pi 2))) (list pi (/ pi 2) 0))
(defun add_solid(p1 p2 p3 p4)
(entmakex (list (cons 0 "SOLID") (cons 100 "AcDbEntity") (cons 62 1) (cons 100 "AcDbTrace")
(cons 10 p1) (cons 11 p2) (cons 12 p3) (cons 13 p4)
(defun add_text(pt h ang txt style jus)
(entmakex (list (cons 0 "TEXT") (cons 100 "AcDbEntity") (cons 62 2) (cons 100 "AcDbText") (if (= jus 0) (cons 10 pt) (list 10 0.0 0.0 0.0)) (cons 40 h)
(cons 1 txt) (cons 50 ang) (cons 7 style) (cons 72 (cond ((= jus 0) 0) ((= jus 1) 1) ((= jus 2) 1) ((= jus 3) 2))) (if (= jus 0)
(list 11 0.0 0.0 0.0) (cons 11 pt)) (cons 100 "AcDbText") (cons 73 (cond ((= jus 0) 0) ((= jus 1) 2) ((= jus 2) 3) ((= jus 3) 2)))
(defun dis(ent / obj laynm name st1 st2 st3 lst h ang n)
(setq obj (vlax-ename->vla-object ent))
(setq laynm (strcat "图层:" (dxf ent 8)) name (dxf ent 0))
(cond
((= name "3DFACE")
(setq lst (list "【三维面】" laynm))
((= name "3DSOLID")
(setq lst (list "【三维实体】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
((= name "ACAD_PROXY_ENTITY")
(setq lst (list "【代理】" laynm))
((= name "ARC")
(setq lst (list "【圆弧】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))
(strcat "圆心角:" (rtos (toang (vla-get-TotalAngle obj) 1) 2 1) "度")
(strcat "起始角:" (rtos (toang (vla-get-StartAngle obj) 1) 2 1) "度")
(strcat "终止角:" (rtos (toang (vla-get-EndAngle obj) 1) 2 1) "度")
(strcat "总弧长:" (rtos (vla-get-ArcLength obj) 2 0))
(strcat "面积:" (rtos (/ (vla-get-Area obj) 1000000) 2 2) "㎡")
((= name "ATTDEF")
(setq lst (list "【属性定义】" laynm (strcat "标签:" (vla-get-TagString obj))
(strcat "提示:" (vla-get-PromptString obj))
(strcat "缺省值:" (vla-get-TextString obj))
(strcat "高度:" (rtos (vla-get-Height obj) 2 0))
(strcat "角度:" (rtos (toang (vla-get-Rotation obj) 1) 2 1) "度")
(strcat "文字样式:" (vla-get-StyleName obj))
((= name "ATTRIB")
(setq lst (list "【属性】" laynm (strcat "标签:" (vla-get-TagString obj))
((= name "BODY")
(setq lst (list "【体】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
((= name "CIRCLE")
(setq lst (list "【圆】" laynm (strcat "半径:" (rtos (vla-get-radius obj) 2 0))
(strcat "周长:" (rtos (vla-get-Circumference obj) 2 0))
((= name "DIMENSION")
(setq lst (list "【尺寸标注】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
(strcat "文字样式:" (vla-get-TextStyle obj))
(strcat "文字高度:" (rtos (vla-get-TextHeight obj) 2 1))
(strcat "替带文字:" (if (= (dxf ent 1) "") "无" (dxf ent 1)))
((= name "ELLIPSE")
(setq lst (list "【椭圆】" laynm (strcat "长轴半径:" (rtos (vla-get-MajorRadius obj) 2 0))
(strcat "短轴半径:" (rtos (vla-get-MinorRadius obj) 2 0))
((= name "HATCH")
(setq lst (list "【图案填充】" laynm (strcat "图案名称:" (vla-get-PatternName obj))
(strcat "角度:" (rtos (toang (vla-get-PatternAngle obj) 1) 2 1))
(strcat "比例:" (rtos (vla-get-PatternScale obj) 2 0))
(strcat "关联:" (if (= (vla-get-AssociativeHatch obj) :vlax-false) "关闭" "打开"))
(strcat "填充样式:" (nth (vla-get-HatchStyle obj) '("普通" "外部" "忽略")))
((= name "IMAGE")
(setq lst (list "【图像】" laynm (strcat "图像大小:" (rtos (car (dxf ent 13)) 2 0) "X" (rtos (cadr (dxf ent 13)) 2 0))))
((= name "INSERT")
(setq lst (list "【图块】" laynm (strcat "名称:" (dxf ent 2))
(strcat "X比例:" (rtos (dxf ent 41) 2 1))
(strcat "Y比例:" (rtos (dxf ent 42) 2 1))
(strcat "Z比例:" (rtos (dxf ent 43) 2 1))
((= name "LEADER")
(setq lst (list "【引线】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
(strcat "引线类型:" (dxf (list (cons 0 "折线") (cons 1 "样条曲线")) (dxf ent 72)))
((= name "LINE")
(setq lst (list "【直线】" laynm (strcat "长度:" (rtos (vla-get-length obj) 2 0))
(strcat "角度:" (rtos (toang (vla-get-angle obj) 1) 2 1) "度")
((= name "LWPOLYLINE")
(setq lst (list "【多段线】" laynm (strcat "常量宽度:" (if (dxf ent 43) (rtos (vla-get-ConstantWidth obj) 2 0) "变宽度"))
(strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))
((= name "MLINE")
(setq lst (list "【多线】" laynm (strcat "多线样式:" (vla-get-StyleName obj))
(strcat "比例因子:" (rtos (dxf ent 40) 2 1))
(strcat "对齐:" (nth (dxf ent 70) '("上" "零" "下")))
((= name "MTEXT")
(setq lst (list "【多行文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
(strcat "样式:" (vla-get-StyleName obj))
((or (= name "OLEFRAME") (= name "OLE2FRAME"))
(setq lst (list "【OLE边框】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
((= name "POINT")
(setq lst (list "【点】" laynm))
((= name "POLYLINE")
(setq lst (list "【三维多段线】" laynm))
((= name "RAY")
(setq lst (list "【射线】" laynm))
((= name "REGION")
(setq lst (list "【面域】" laynm (strcat "格式版本号:" (itoa (dxf ent 70)))))
((= name "SHAPE")
(setq lst (list "【形】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
(strcat "宽度系数:" (rtos (vla-get-ScaleFactor obj) 2 1))
((= name "SOLID")
(setq lst (list "【实体】" laynm))
((= name "SPLINE")
(setq lst (list "【样条曲线】" laynm (strcat "多段线:" (if (= (vla-get-Closed obj) :vlax-false) "不闭合" "闭合"))
(strcat "阶数:" (rtos (vla-get-Degree obj) 2 0))
((= name "TEXT")
(setq lst (list "【文字】" laynm (strcat "高度:" (rtos (vla-get-Height obj) 2 0))
(strcat "对齐:" (nth (vla-get-Alignment obj) '("Left" "Center" "Right" "Aligned" "Middle" "Fit" "TopLeft" "TopCenter" "TopRight"
"MiddleLeft" "MiddleCenter" "MiddleRight" "BottomLeft" "BottomCenter" "BottomRight")))
((= name "TOLERANCE")
(setq lst (list "【公差】" laynm (strcat "标注样式:" (vla-get-StyleName obj))
((= name "TRACE")
(setq lst (list "【宽线】" laynm))
((= name "VERTEX")
(setq lst (list "【顶点】" laynm (strcat "起始宽度:" (rtos (dxf ent 40) 2 0))
(strcat "结束宽度:" (rtos (dxf ent 41) 2 0))
(strcat "凸度:" (rtos (dxf ent 42) 2 1))
((= name "XLINE")
(setq lst (list "【构造线】" laynm))
(T
(setq lst (list "【未知对象】" laynm))
(setq ss (ssadd) h (/ (getvar "viewsize") 50))
(setq ang (fx (angle (getvar "viewctr") pt)))
(setq n (* 1.4 (1+ (/ (apply 'max (mapcar 'strlen lst)) 2.0))))
(ssadd (add_solid pt (polar pt (car ang) (* n h)) (setq pt (polar pt (cadr ang) (+ h (* 1.8 h (length lst))))) (polar pt (car ang) (* n h))) ss)
(setq pt (polar pt (car ang) (/ (* n h) 2)))
(if (= (caddr ang) 0)
(setq pt (polar pt (/ pi 2) (* 0.4 h)))
(setq pt (polar pt (/ pi 2) (+ (* 1.4 h) (* 1.8 h (length lst)))))
(setq n -1)
(repeat (length lst)
(ssadd (add_text (setq pt (polar pt (+ pi (/ pi 2)) (* 1.8 h))) h 0 (nth (setq n (1+ n)) lst) "宋体" 1) ss)
(vl-load-com)
(command "_.undo" "_m")
(prompt "\n***....鼠标掠过对象查看信息!***")
(setq olderr *error* *error* myerr)
(setq oldos (getvar "osmode"))
(setq oldfill (getvar "fillmode"))
(setvar "osmode" 0)
(setvar "fillmode" 1)
(setvar "cmdecho" 0)
(if (not (tblsearch "style" "宋体"))
(command "_.style" "宋体" "宋体" "" "" "" "" "")
(setq ss (ssadd))
(while (not pd)
(while (not (progn
(setq gr (grread T 1))
(if (= (car gr) 5)
(setq pt (cadr gr)
ent (nentselp pt)
ent (if (and ent (= (type (last (last ent))) 'ename))
(last (last ent))
(car ent)
(setq pd T)
(if (and (not pd) (not (equal ent entold)) (not (ssmemb ent ss)))
(progn
(if entold (redraw entold 4))
(if ss (command "_.erase" ss ""))
(redraw ent 3)
(dis ent)
(setq entold ent)
(setvar "osmode" oldos)
(setvar "fillmode" oldfill)
(princ)
(princ)
////////////////////////////////////////////////////////////////////////结束
发表于 2006-12-1 14:30:52 | 显示全部楼层
cad2006及以上版本已自带该功能,不用了,谢谢。
发表于 2006-12-1 22:41:59 | 显示全部楼层
好东西,CASS51也有,就是不知怎么做的,下载下来好好学学。支持!
发表于 2006-12-3 11:51:05 | 显示全部楼层
支持!不错!
XD上前段时间也有类似的帖子,百花齐放,各有千秋。
已领礼包: 2个
发表于 2006-12-4 18:28:27 | 显示全部楼层
发表于 2006-12-4 19:47:13 | 显示全部楼层
2000和R14能用吗?
发表于 2006-12-5 10:10:19 | 显示全部楼层
2002没法用。
 楼主| 发表于 2006-12-5 11:05:49 | 显示全部楼层
2004可用,其它的不清楚
发表于 2007-2-22 21:20:20 | 显示全部楼层
谢谢!
发表于 2007-2-22 21:57:05 | 显示全部楼层
呵呵
多年前的东东了
虽然有更好的即时显示的程序
但这个用LISP写的还是比较经典
无论对于学习编程还是实用性都不错
俺的显筋面积有个版本也利用了这个程序的主框架部分
GMT+8, 2026-11-7 04:33 , Processed in 1.192976 second(s), 61 queries , Gzip On.
