查看: 1388|回复: 3
[ARX程序]:帮我看看这段程序
发表于 2002-5-21 03:39:55 | 显示全部楼层 |阅读模式
AcDbDatabase *pDb=new AcDbDatabase;
        //ads_name en;
        AcDbObjectId eId;
        AcDbCircle * pCir;
            pDb->readDwgFile("strFileName");
        AcDbBlockTable *pBlockTable;
        pDb->getBlockTable(pBlockTable,AcDb::kForRead);
        AcDbBlockTableRecord *pBlockTableRecord;
        pBlockTable->getAt(ACDB_MODEL_SPACE,pBlockTableRecord,AcDb::kForWrite);
        pBlockTable->close();
        //AcDbObjectId circleId;
        AcDbBlockTableRecordIterator *pBlkTblRcdItr;
        pBlockTableRecord->newIterator(pBlkTblRcdItr);
        for(pBlkTblRcdItr->start();!pBlkTblRcdItr->done();pBlkTblRcdItr->step())
                AcDbEntity *pEnt;
                pBlkTblRcdItr->getEntity(pEnt,AcDb::kForRead);
        pBlkTblRcdItr->getEntityId (eId);
                acdbOpenObject(pCir, eId, AcDb::kForRead);
        if (pCir)
                        AcGePoint3d sPt;
                        pCir->AcDbCircle::cast(pEnt);
                        sPt=pCir->center();
                        m_nX=sPt.x;
                        m_nY=sPt.y;
                        m_nZ=sPt.z;
                        double radius=pCir->radius();
                        m_nRad=radius;
                        i++;
                        pCir->close();
                pEnt->close();
        pBlockTableRecord->close();
        delete pBlkTblRcdItr;
        delete pDb;
已领礼包: 13个
发表于 2002-5-21 04:00:00 | 显示全部楼层
程序怎么了? 最好把你的错误描述出来才好看,编译错误贴出错误信息,运行错误贴出错误信息,不能实现你的想法的,说下程序做的结果等等,这样才好帮你。
 楼主| 发表于 2002-5-21 07:01:11 | 显示全部楼层
打开Dwg图形数据库,遍历块表得到实体,读取里面的信息,如园的圆心座标和半径。
谢谢!
发表于 2002-5-22 02:33:40 | 显示全部楼层
有问题
acdbOpenObject(pCir, eId, AcDb::kForRead);是操作当前的数据库
//ads_name en;
AcDbObjectId eId;
AcDbCircle * pCir;
AcDbEntity *pEnt;
if(((AcDbObject*&)pEnt)->isKindOf(AcDbCircle::desc())){
AcGePoint3d sPt;
sPt=pCir->center();
m_nX=sPt.x;
m_nY=sPt.y;
m_nZ=sPt.z;
m_nRad=radius;
i++;
pEnt->close();
delete pDb
GMT+8, 2026-11-2 21:38 , Processed in 0.476574 second(s), 38 queries , Gzip On.
