查看: 990|回复: 0
[求助] [求助]:画弧形半圆键形
发表于 2007-1-23 02:20:30 | 显示全部楼层 |阅读模式
求高人纠错
我想画弧形半圆键形
这个弧度函数让我糊涂了
下面程序错在那里大伙帮忙看看
(defun c:hj (/ p0 p1 dis widf disf ang1 p2 p3 p4 p5)
    (setq p0 (getpoint "\n>请指定弧心:"))
    (setq p1 (getpoint p0 "\n>>指定弧键中心点:"))
    (setq dis (distance p0 p1))
    (setq widf wid)
    (if (null widf)
        (setq widf 5)
    (setq wid (getdist (strcat "\n>>>输入半圆键半径默认< " (rtos widf) " >...:")))
    (if (null wid)
        (setq wid widf)
    (setq disf dis)
    (if (null disf)
        (setq disf 20)
    (setq dish (getdist (strcat "\n>>>输入中心弧长默认< " (rtos disf)
    (if (null dish)
        (setq dish disf)
    )                                  ;   (setq os (getvar "osmode"))
    (setq ang1 (abs (/ (- (* 0.5 dish) wid) dis)))
    (setq p2 (polar p0 (+ (angle p0 p1) ang1) (- dis wid)))
    (setq p3 (polar p0 (- (angle p0 p1) ang1) (- dis wid)))
    (setq p4 (polar p0 (+ (angle p0 p1) ang1) (+ dis wid)))
    (setq p5 (polar p0 (- (angle p0 p1) ang1) (+ dis wid))) ;   (setvar "osmode"
                                       ; 0)
    (command "pline" "a" "non" p2 "non" p3 "non" p5 "non" p4 "cl") ;   (setvar
                                       ; "osmode" os)
    (princ (strcat "\nok!^.^ 已完成!:" (rtos dish) "×" (rtos wid)))
    (princ)
GMT+8, 2026-11-3 20:09 , Processed in 0.537497 second(s), 32 queries , Gzip On.
