查看: 1486|回复: 3
[求助]:在vba中怎样把图中属性块的各属性值读出
发表于 2007-1-25 14:51:20 | 显示全部楼层 |阅读模式
在vba中怎样把图中属性块的各属性值读出,并把每个块的坐标和各属性值在图中标注
 楼主| 发表于 2007-1-26 14:27:00 | 显示全部楼层
没有高手能帮小弟的忙吗?
发表于 2007-1-29 15:58:08 | 显示全部楼层
Sub TEST()
Dim BRE As AcadBlockReference
Dim obj As AcadEntity
ThisDrawing.Utility.GetEntity obj, v, vbCrLf & "选择块对象:"
If obj.ObjectName = "AcDbBlockReference" Then
Set BRE = obj
Dim S As Variant
Dim str As String
str = BRE.Name + "的属性值:"
Dim i As Integer
S = BRE.GetAttributes
  For i = LBound(S) To UBound(S)
          str = str + vbCrLf + S(i).TagString
          str = str + ":" + S(i).TextString
   Next
   MsgBox str
End If
End Sub
 楼主| 发表于 2007-2-5 08:51:39 | 显示全部楼层
高手能把上面附件中的各块属性全部读出,并在图中标出各块属性和各块的插入坐标吗?
GMT+8, 2026-11-22 08:20 , Processed in 0.303422 second(s), 14 queries , Gzip On, File On.
