查看: 918|回复: 0
[转贴]:计算线加总长度
发表于 2007-1-27 18:56:15 | 显示全部楼层 |阅读模式
;;;计算线加总长度
(defun C:LENOF (/ CURVE TLEN SS N SUMLEN)
(vl-load-com)
(setq SUMLEN 0)
(setq SS (ssget '((0 . "CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC"))))
(setq N 0)
(repeat (sslength SS)
(setq CURVE (vlax-ename->vla-object (ssname SS N)))
(setq TLEN (vlax-curve-getdistatparam
CURVE
(vlax-curve-getendparam CURVE)
(setq SUMLEN (+ SUMLEN TLEN))
(setq N (1+ N))
(print (strcat "总长度: " (rtos SUMLEN 2 5)))
(princ)
GMT+8, 2026-11-7 11:37 , Processed in 0.405849 second(s), 32 queries , Gzip On.
