查看: 1335|回复: 2
[LISP程序]:简化版htb.lsp
发表于 2007-2-25 19:34:40 | 显示全部楼层 |阅读模式
;;;重建填充边界
(defun c:htb () (c:hatchb))
(defun c:hatchb        (/         es         blay         ed1         ed2         loops1         bptf         part         et         noe
                 plist         ic         bul         nr         ang1         ang2         obj         space         cw         errexit
                 olderr         oldcmdecho         ss1         lastent en1         en2         ss         lwp         ent
                 i         ss2         knot-list         controlpoint-list         kn         cn
                 pos         xv         bot         area         hst     ent1
  (setq        olderr        *error*
        *error*        errexit
        space        (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
  (if (setq ss2 (ssget '((0 . "HATCH"))))
    (progn
      (setq area 0
            i -1)
      (while (setq ent (ssname ss2 (setq i (1+ i))))
        (setq ed1 (entget ent)
              xv  (cdr (assoc 210 ed1))
              loops1 (cdr (assoc 91 ed1));|边界路径(环)数|; );end setq
        (if (not (equal (assoc 210 ed1) '(210 0.0 0.0 1.0))) (princ "\nHatch not in WCS!"));end if
        (command "._ucs" "_w")
        (repeat        loops1
          (setq        ed1   (member (assoc 92 ed1) ed1)
                bptf  (cdr (car ed1))        ; boundary path type flag
                ic    (cdr (assoc 73 ed1)) ; “关闭”标志
                noe   (cdr (assoc 93 ed1)) ; 多段线顶点数
                bot   (cdr (assoc 92 ed1)) ; 边界路径类型标志(按位编码):0 = 默认;1 = 外部;2 = 多段线4 = 导出;8 = 文本框;16 = 最外层
                hst   (cdr (assoc 75 ed1)) ; 图案填充样式:0 = 填充“奇校验”区域(“普通”样式)1 = 仅填充最外层区域(“外部”样式)2 = 填充整个区域(“忽略”样式)
                ed1   (member (assoc 72 ed1) ed1);边类型(仅当边界不是多段线时):1 = 直线;2 = 圆弧;3 = 椭圆弧;4 = 样条曲线
                bul   (cdr (car ed1))        ; bulge
                plist nil
                blist nil );end setq
          (cond
            ((> (boole 1 bptf 2) 0)        ;cond1 polyline
             (repeat noe
               (setq ed1   (member (assoc 10 (cdr ed1)) ed1)
                     plist (append plist (list (cdr (assoc 10 ed1))))
                     blist (append blist (if (> bul 0) (list (cdr (assoc 42 ed1))) nil)))
             (setq polypoints (apply 'append (mapcar '3dPoint->2dPoint plist))
                   VLADataPts (list->variantArray polypoints)
                   obj              (vla-addLightweightPolyline space VLADataPts)
                   nr              0);ent setq
             (repeat (length blist)
               (if (/= (nth nr blist) 0)
                 (vla-setBulge obj nr (nth nr blist)))
               (setq nr (1+ nr)));end repeat
             (if (= ic 1) (vla-put-closed obj T))
             );end cond1
            (t                                ;cond2 not polyline
             (setq lastent (entlast)
                   lwp           T)
             (repeat noe                ;repeat s
               (setq et (cdr (assoc 72 ed1)))
               (cond
                 ((= et 1)                ;cond21 line
                  (setq ed1 (member (assoc 10 (cdr ed1)) ed1))
                  (vla-AddLine space (vlax-3d-point (cdr (assoc 10 ed1)))
                    (vlax-3d-point (cdr (assoc 11 ed1))))
                  (setq ed1 (cddr ed1))
                 );end cond21
                 ((= et 2)                ;cond22 circular arc
                        ang1 (cdr (assoc 50 ed1))
                        ang2 (cdr (assoc 51 ed1))
                        cw   (cdr (assoc 73 ed1)))
                  (if (equal ang2 6.28319 0.00001)
                    (progn (vla-AddCircle space (vlax-3d-point (cdr (assoc 10 ed1)))
                             (cdr (assoc 40 ed1))) (setq lwp nil))
                    (vla-AddArc
                      space
                      (if (= cw 0) (- 0 ang2) ang1)
                      (if (= cw 0) (- 0 ang1) ang2)
                      ));end if
                  (setq ed1 (cddddr ed1))
                 );end cond22
                 ((= et 3)                ;cond23 elliptic arc
                        obj  (vla-AddEllipse
                               space
                  (vla-put-startangle obj (if (= cw 0) (- 0 ang2) ang1))
                  (vla-put-endangle obj (if (= cw 0) (- 0 ang1) ang2))
                  (setq lwp nil)
                  );end cond23
                 ((= et 4)                ;cond24 spline
                  (setq        ed1                  (member (assoc 94 (cdr ed1)) ed1)
                        knot-list          nil
                        controlpoint-list nil
                        kn                  (cdr (assoc 95 ed1))
                        cn                  (cdr (assoc 96 ed1))
                        pos                  (vl-position (assoc 40 ed1) ed1))
                  (repeat kn
                    (setq knot-list (cons (cons 40 (cdr (nth pos ed1))) knot-list)
                          pos            (1+ pos)))
                  (setq pos (vl-position (assoc 10 ed1) ed1))
                  (repeat cn
                    (setq controlpoint-list (cons (cons 10 (cdr (nth pos ed1)))
                                                  controlpoint-list) pos (1+ pos))
                  (setq        knot-list          (reverse knot-list)
                        controlpoint-list (reverse controlpoint-list))
                  (entmake (append
                             (list '(0 . "SPLINE"))
                             (list (cons 100 "AcDbEntity"))
                             (list (cons 100 "AcDbSpline"))
                             (list (cons 70 (+ 1 8 (* 2 (cdr (assoc 74 ed1)))
                                               (* 4 (cdr (assoc 73 ed1))))))
                             (list (cons 71 (cdr (assoc 94 ed1))))
                             (list (cons 72 kn))
                             (list (cons 73 cn))
                             knot-list
                             controlpoint-list
                           S
                           );end entmake
                  (setq        ed1 (member (assoc 10 ed1) ed1)
                        lwp nil )
                  );end cond24
                 );end repeat
               );end cond2
             (if lwp (progn
                       (setq en1 (entnext lastent)
                             ss  (ssadd))
                       (ssadd en1 ss)
                       (while (setq en2 (entnext en1))
                         (ssadd en2 ss)
                         (setq en1 en2))
                       (if (= (getvar "peditaccept") 1)
                         (command "_.pedit" (entlast) "_J" ss "" "")
                         (command "_.pedit" (entlast) "_Y" "_J" ss "" ""))
                       );|end progn|; );end if
             );end cond
          );end repeat
        (setq ent1 (entget (entlast)))
        (setq ent1 (append (subst (cons 8 "COLU") (assoc 8 ent1) ent1)))
        (entmod ent1)
        (entdel ent)
        );end while
      );end progn
    );end if
  );end defun
(defun errexit (s)
  (princ "\nError:  ")
  (princ s)
(defun 3dPoint->2dPoint        (3dpt)
  (list (float (car 3dpt)) (float (cadr 3dpt)))
(defun list->variantArray (ptsList / arraySpace sArray)
  (setq        arraySpace (vlax-make-safearray vlax-vbdouble (cons 0 (- (length ptsList) 1)))
        sArray           (vlax-safearray-fill arraySpace ptsList))
  (vlax-make-variant sArray)
发表于 2007-2-25 23:05:45 | 显示全部楼层
有弧,样条曲线,椭圆弧,会出错
发表于 2007-3-3 22:15:06 | 显示全部楼层
试了不是很好用,有时会出错
GMT+8, 2026-11-7 11:36 , Processed in 0.469772 second(s), 35 queries , Gzip On.
