查看: 5497|回复: 8
[原创]:在grread状态下实现捕捉功能并显示标记符号
发表于 2007-3-3 14:00:15 | 显示全部楼层 |阅读模式
TheSwamp.org上的联接:
http://www.theswamp.org/index.php?topic=12797.0
调用grread获取原始点,然后通过osnap函数捕捉准确点,并调用grvecs画出自动捕捉记号
我为了能发表在TheSwamp.org,所以很多说明是用英文写的,请大家见谅.
CAB的原代码只写了grread+osnap,判断及加入绘制捕捉记号的部分是我添加上的
[php]
;;  Grread+osnap+GRVECS
;;  Rewritten by Fools @ TheSwamp.org
;;  Use (grread) to get original point
;;  Use (osnap) to calculate accurate point
;;  Use (GRVECS) to show AutoSnapMarker
;;  No return , just show the method
(DEFUN c:tmp (/                      AUTOSNAPMARKERCOLOR              AUTOSNAPMARKERSIZE
              DRAG              GHOSTPT              LST_OSMODE      STR_OSMODE      TIME
              DistPerPixel    Bold              Draftobj              get_osmode      YPY_StrParse
              YPY_GetGrvecs   YPY_DrawVecs
  ;;  CAB  10/5/2006
  ;;  Fools change a little about ","  (3/3/2007)
  ;;  Function to return the current osmode setting in the form of a string
  ;;  If (getvar "osmode") = 175
  ;;  (get_osmode)  returns   "_end,_mid,_cen,_nod,_int,_per"
  (DEFUN get_osmode (/ cur_mode mode$)
    (SETQ mode$ "")
    (IF        (< 0 (SETQ cur_mode (GETVAR "osmode")) 16383)
      (MAPCAR (FUNCTION        (LAMBDA        (x)
                          (IF (NOT (ZEROP (LOGAND cur_mode (CAR x))))
                            (IF        (ZEROP (STRLEN mode$))
                              (SETQ mode$ (CADR x))
                              (SETQ mode$ (STRCAT mode$ "," (CADR x)))
              '((1 "_end")
                (2 "_mid")
                (4 "_cen")
                (8 "_nod")
                (16 "_qua")
                (32 "_int")
                (64 "_ins")
                (128 "_per")
                (256 "_tan")
                (512 "_nea")
                (1024 "_qui")
                (2048 "_app")
                (4096 "_ext")
                (8192 "_par")
    mode$
  ;;My functions
  (DEFUN YPY_StrParse (str delim / ptr lst)
    (WHILE (SETQ ptr (VL-STRING-SEARCH delim str))
      (SETQ lst (CONS (SUBSTR str 1 ptr) lst))
      (SETQ str (SUBSTR str (+ ptr 2)))
  (REVERSE (CONS str lst))
  (DEFUN YPY_GetGrvecs (pt dragpt lst / KEY)
    (SETQ key T)
    (WHILE (AND key lst)
      (IF (EQUAL (OSNAP dragpt (CAR lst)) pt 1E-6)
        (SETQ key nil)
        (SETQ lst (CDR lst))
    (CDR (ASSOC        (CAR lst)
                '(("_end"
                   ((-1 1) (-1 -1))
                   ((-1 -1) (1 -1))
                   ((1 -1) (1 1))
                   ((1 1) (-1 1))
                  )                        ;square
                  ("_mid"
                   ((0 1.414) (-1.225 -0.707))
                   ((-1.225 -0.707) (1.225 -0.707))
                   ((1.225 -0.707) (0 1.414))
                  )                        ;triangle
                  ("_cen"
                   ((0 1) (-0.707 0.707))
                   ((-0.707 0.707) (-1 0))
                   ((-1 0) (-0.707 -0.707))
                   ((-0.707 -0.707) (0 -1))
                   ((0 -1) (0.707 -0.707))
                   ((0.707 -0.707) (1 0))
                   ((1 0) (0.707 0.707))
                   ((0.707 0.707) (0 1))
                  )                        ;circle
                  ("_nod"
                   ((-1 1) (1 -1))
                   ((-1 -1) (1 1))
                  )                        ;circle+cross
                  ("_qua"
                   ((0 1.414) (-1.414 0))
                   ((-1.414 0) (0 -1.414))
                   ((0 -1.414) (1.414 0))
                   ((1.414 0) (0 1.414))
                  )                        ;square rotate 45
                  ("_int"
                   ((-1 1) (1 -1))
                   ((-1 -1) (1 1))
                   ((1 0.859) (-0.859 -1))
                   ((-1 0.859) (0.859 -1))
                   ((0.859 1) (-1 -0.859))
                   ((-0.859 1) (1 -0.859))
                  )                        ;cross
                  ("_ins"
                   ((-1 1) (-1 -0.1))
                   ((-1 -0.1) (0 -0.1))
                   ((0 -0.1) (0 -1.0))
                   ((0 -1.0) (1 -1))
                   ((1 -1) (1 0.1))
                   ((1 0.1) (0 0.1))
                   ((0 0.1) (0 1.0))
                   ((0 1.0) (-1 1))
                  )                        ;two squares
                  ("_per"
                   ((-1 1) (-1 -1))
                   ((-1 -1) (1 -1))
                   ((0 -1) (0 0))
                   ((0 0) (-1 0))
                  )                        ;half square
                  ("_tan"
                   ((1 1) (-1 1))
                  )                        ;circle+line
                  ("_nea"
                   ((-1 1) (1 -1))
                   ((1 -1) (-1 -1))
                   ((-1 -1) (1 1))
                   ((1 1) (-1 1))
                  )                        ;two triangle
                  ("_qui")                ; ???
                  ("_app"
                   ((-1 1) (-1 -1))
                   ((-1 -1) (1 -1))
                   ((1 -1) (1 1))
                   ((1 1) (-1 1))
                   ((-1 1) (1 -1))
                   ((-1 -1) (1 1))
                  )                        ;square+cross
                  ("_ext"
                   ((0.1 0) (0.13 0))
                   ((0.2 0) (0.23 0))
                   ((0.3 0) (0.33 0))
                  )                        ;three points
                  ("_par" ((0 1) (-1 -1)) ((1 1) (0 -1))) ;two lines
  ;;Use GRVECS
  (DEFUN YPY_DrawVecs (Pt Vecs Size Color / lst matrix)
    ;;no Z axis
    (SETQ matrix (LIST (LIST Size 0.0 0.0 (CAR pt))
                       (LIST 0.0 Size 0.0 (CADR pt))
                       (LIST 0.0 0.0 1.0 0.0)
                       (LIST 0.0 0.0 0.0 1.0)
    (SETQ lst (MAPCAR 'CONS
                      (MAPCAR (FUNCTION (LAMBDA (x) Color)) Vecs)
                      Vecs
    (GRVECS (APPLY 'APPEND lst) matrix)
  ;;  Main Routine starts here
  (VL-LOAD-COM)
  (SETQ time T)
  (SETQ str_osmode (get_osmode))
  (SETQ lst_osmode (YPY_StrParse str_osmode ","))
  (SETQ        Draftobj (VLA-GET-DRAFTING
                   (VLA-GET-PREFERENCES (VLAX-GET-ACAD-OBJECT))
  (SETQ AutoSnapMarkerSize (VLA-GET-AUTOSNAPMARKERSIZE Draftobj))
  (SETQ AutoSnapMarkerColor (VLA-GET-AUTOSNAPMARKERCOLOR Draftobj))
  (WHILE time
    (grread (SETQ drag (GRREAD T 1 1))) ;;Can change like (grread T 15 2)
    (COND ((= (CAR drag) 5)
           (REDRAW)
           (SETQ drag (CADR drag))
           (IF (or (zerop (strlen str_osmode)) (NULL (SETQ ghostpt (OSNAP drag str_osmode))))
             (SETQ ghostpt drag)
             ;;Beacuse of mouse middle button scroll , calculate "DistPerPixel" every time
             (PROGN (SETQ DistPerPixel (/ (GETVAR "VIEWSIZE") (CADR (GETVAR "SCREENSIZE"))))
                    ;;Bold
                    (SETQ Bold (MAPCAR '*
                                       (LIST DistPerPixel DistPerPixel DistPerPixel)
                                       (LIST (+ AutoSnapMarkerSize 0.5)
                                             AutoSnapMarkerSize
                                             (- AutoSnapMarkerSize 0.5)
                    (FOREACH item Bold
                      (YPY_DrawVecs
                        ghostpt
                        (YPY_GetGrvecs ghostpt drag lst_osmode)
                        item
                        AutoSnapMarkerColor
          ((= (CAR drag) 3)
           (IF (NULL (SETQ ghostpt (OSNAP (CADR drag) (get_osmode))))
             (SETQ ghostpt (CADR drag))
           (REDRAW)
           (SETQ time nil)
  (PRINC) ;can return ghostpt if want
[/php]
发表于 2007-3-3 16:28:54 | 显示全部楼层
楼主:测试时发现,当关闭捕捉时运行会出错。
增加一个条件选择即可解决问题。修改部分如下所示:
[PHP]
    (WHILE time
        (GRREAD (SETQ drag (GRREAD T 1 1)))
        (COND
            ((= (CAR drag) 5)
             (REDRAW)
             (IF (OR (= 0 (GETVAR "osmode"))
                     (> (GETVAR "osmode") 15359)
                 (SETQ ghostpt drag)
                 (IF (NULL (SETQ ghostpt (OSNAP drag str_osmode)))
                     (SETQ ghostpt drag)
                     (FOREACH item Bold
                         (YPY_DrawVecs
                             ghostpt
                             item
                             AutoSnapMarkerColor
            ((= (CAR drag) 3)
             (REDRAW)
             (SETQ time nil)
[/PHP]
另:"AutoSnap Marker Size"和"AutoSnap marker color"可以通过(vlax-get-acad-object)函数得到模型树,并进一步分析之得到。
 楼主| 发表于 2007-3-3 19:34:50 | 显示全部楼层
多谢zml84!
有关的"AutoSnap Marker Size"和"AutoSnap marker color"获取,首贴已经更新!
另外更新了DistPerPixel获取,主要是避免中键缩放的影响.
你提到的取消捕捉发生错误,是因为我以为(osnap pt "")将返回nil,结果不是,而是一个点,加入判断str_osmode是否为""即可,首贴已更新.
[php]
             (SETQ ghostpt drag)
              (PROGN         ...   )
[/php]
如果觉得捕捉时显示十字光标不好看可以改变grread的参数,以实现
不显示十字光标或显示为对象选择光标,甚至可以另画一个光标,:)
例如将(grread (SETQ drag (GRREAD T 1 1)))改为(GRREAD T 15 2)
程序还有许多不足之处,请大家多提宝贵意见.
发表于 2007-3-4 13:55:45 | 显示全部楼层
有创意,要是能实现极轴追踪就更牛了
发表于 2007-3-4 15:53:00 | 显示全部楼层
费这么大劲,还不如arx,我反正是arx了。
其实arx里捕捉显示的原理也是这样的.
考虑东西还有很多
比如 极轴 对象追踪 磁吸 中间打入另一个捕捉 输入距离 透明命令 等等
而且要把函数包装起来,不然每次要用,都要拷贝这么多的代码,不是很好.
 楼主| 发表于 2007-3-4 22:18:11 | 显示全部楼层
获取AutoSnapMarker 颜色和尺寸,也可以用下面这种方法
(getenv "AutoSnapColor")
(getenv "AutoSnapSize")
发表于 2007-3-22 00:18:28 | 显示全部楼层
很好的资料,顶起来!
发表于 2014-4-18 16:49:31 | 显示全部楼层
好代码,正在找类似的功能
发表于 2016-8-29 09:35:05 | 显示全部楼层
很好的资料,顶起来!
GMT+8, 2026-11-22 09:55 , Processed in 0.429991 second(s), 26 queries , Gzip On, File On.
