查看: 658|回复: 1
[建议]:裁减命令T的运用
发表于 2007-4-27 12:34:08 | 显示全部楼层 |阅读模式
建议用裁减命令T的时候自动关闭按组选取方式。
发表于 2007-4-27 13:00:54 | 显示全部楼层
  1.   [FONT=courier new]
  2. (defun ee_err (s)
  3.   (setvar "cmdecho" cm)
  4.   (setvar "pickstyle" ps)
  5.   (command "_.undo" "_e")
  6. )
  7. (defun c:t ()
  8.   (princ "\n* 修剪对象→|边=延伸、组选=关闭| *")
  9.   (setq cm (getvar "cmdecho"))
  10.   (setq ps (getvar "pickstyle"))
  11.   (setq *error* ee_err)
  12.   (setvar "cmdecho" 1)
  13.   (setvar "pickstyle" 0)
  14.   (setvar "edgemode" 1)
  15.   (princ "\n选择对象或 <全部选择>:")
  16.   (if (setq ss (ssget))
  17.       (command ".trim" ss "")
  18.       (command ".trim" "" "e" "n")
  19.   )
  20.   (while (/= 0 (getvar "cmdactive")) (command pause))
  21.   (setvar "cmdecho" cm)
  22.   (setvar "pickstyle" ps)
  23.   (princ)
  24. )
  25.   [/FONT]
GMT+8, 2026-11-4 06:45 , Processed in 0.545793 second(s), 32 queries , Gzip On.
