查看: 1774|回复: 3
[分享]:图层全部操作(凑热闹)
发表于 2007-5-5 21:46:24 | 显示全部楼层 |阅读模式
声明:自己用了很长时间。(谁用谁知道)
      里面只有tcc是我自己写的。其它的不知道是哪位高手写的
[php]
(defun c:TC()
(alert
"\n                    以下是图层操作命令:
\nTCC 选中设置为当前
\nTCS 孤立(LAYISO)  TCR 当前(LAYCUR)  TCH 匹配(LAYMCH)
\nTCF 关闭(LAYOFF)  TCT 打开(LAYON)   TCK 锁定(LAYLCK)
\nTCU 解锁(LAYULK)  TCZ 冻结(LAYFRZ)  TCW  解冻(LAYTHW)
(defun c:tcc(/ nn ss)
  (setq cmd_orig (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (setq na (car (entsel "\n选择对象:")))
  (setq data (entget na))
  (setq faq1 (cdr (assoc 8 data)))
  (setq faq2 (cdr (assoc 6 data)))
  (if (= nil faq2)
    (progn
      (command "celtype" "bylayer")
     (command "celtype" faq2)
  (setq faq3 (cdr (assoc 62 data)))
  (if (= nil faq3)
     (progn
    (command "cecolor" 256)
     (setvar "cecolor" (itoa faq3))
  (setvar "clayer" faq1)
  (setvar "cmdecho" cmd_orig)
(prin1)
(Defun C:TCS (/ SS CNT LAY LAYLST VAL)
(setvar "cmdecho" 0)    ; cmdecho = 0
  (if (not (setq SS (ssget "i")))
    (progn
      (prompt "\nSelect object(s) on the layer(s) to be ISOLATED: ")
      (setq SS (ssget))
  (if SS
    (progn
      (setq CNT 0)
      (while (setq LAY (ssname SS CNT))
        (setq LAY (cdr (assoc 8 (entget LAY))))
        (if (not (member LAY LAYLST))
          (setq LAYLST (cons LAY LAYLST))
        (setq CNT (1+ CNT))
      (if (member (getvar "CLAYER") LAYLST)
        (setq LAY (getvar "CLAYER"))
        (setvar "CLAYER" (setq LAY (last LAYLST)))
      (command "_.-LAYER" "_OFF" "*" "_Y")
      (foreach VAL LAYLST (command "_ON" VAL))
      (command "")
      (if (= (length LAYLST) 1)
        (prompt (strcat "\nLayer " (car LAYLST) " has been isolated."))
        (prompt (strcat "\n" (itoa (length LAYLST)) " layers have been isolated. "
                        "Layer " LAY " is current."
  (princ)
; -------------------- LAYER FREEZE FUNCTION ---------------------
; Freezes selected object's layer
(defun C:TCZ ()
  (layproc "frz")
  (princ)
; ---------------------- LAYER OFF FUNCTION ----------------------
; Turns selected object's layer off
(defun C:TCF ()
  (layproc "off")
  (princ)
; ------------- LAYER PROCESSOR FOR LAYOFF & LAYFRZ --------------
; Main program body for LAYOFF and LAYFRZ. Provides user with
; options for handling nested entities.
(defun LAYPROC ( TASK / NOEXIT OPT BLKLST CNT EN PMT ANS LAY NEST BLKLST)
; -------------------- Variable initialization -------------------
  (setq NOEXIT T)
  (setq OPT (getcfg (strcat "AppData/AC_Bonus/Lay" TASK)))    ; get default option setting
  (if (not (or (null OPT) (= OPT ""))) (setq OPT (atoi OPT)))
  (setq CNT 0)                                                ; cycle counter
  (while NOEXIT
    (initget "Options Undo")
    (if (= TASK "off")
      (setq EN (nentsel "\nOptions/Undo/<Pick an object on the layer to be turned OFF>: "))
      (setq EN (nentsel "\nOptions/Undo/<Pick an object on the layer to be FROZEN>: "))
; ------------------------- Set Options --------------------------
    (While (= EN "Options")
      (initget "No Block Entity")
      (cond
        ((= OPT 1)
          (setq PMT "\nBlock level nesting/Entity level nesting/<No nesting>: ")
        ((= OPT 2)
          (setq PMT "\nBlock level nesting/No nesting/<Entity level nesting>: ")
        (T
          (setq PMT "\nEntity level nesting/No nesting/<Block level nesting>: ")
      (setq ANS (getkword PMT))
      (cond
        ((null ANS)
          (if (or (null OPT) (= OPT ""))
            (progn
              (print ANS)
              (setq OPT 3)
              (setcfg (strcat "AppData/AC_Bonus/Lay" TASK) "3")
        ((= ANS "No")
          (setq OPT 1)
          (setcfg (strcat "AppData/AC_Bonus/Lay" TASK) "1")
        ((= ANS "Entity")
          (setq OPT 2)
          (setcfg (strcat "AppData/AC_Bonus/Lay" TASK) "2")
        (T
          (setq OPT 3)
      (initget "Options")
      (if (= TASK "off")
; ------------------------- Find Layer ---------------------------
    (if (and EN (not (= EN "Undo")))
      (progn
        (setq BLKLST (last EN))
        (setq NEST (length BLKLST))
        (cond
      ; If the entity is not nested or if the option for entity
      ; level nesting is selected.
          ((or (= OPT 2) (< (length EN) 3))
            (setq LAY (entget (car EN)))
      ; If no nesting is desired
          ((= OPT 1)
            (setq LAY (entget (car (reverse BLKLST))))
      ; All other cases (default)
          (T
            (setq BLKLST (reverse BLKLST))
            (while (and                         ; strip out xrefs
                ( > (length BLKLST) 0)
                (assoc 1 (tblsearch "BLOCK" (cdr (assoc 2 (entget (car BLKLST))))))
                   );and
              (setq BLKLST (cdr BLKLST))
            (if ( > (length BLKLST) 0)          ; if there is a block present
              (setq LAY (entget (car BLKLST)))  ; use block layer
              (setq LAY (entget (car EN)))      ; else use layer of nensel
; ------------------------ Process Layer -------------------------
        (setq LAY (cdr (assoc 8 LAY)))
        (if (= LAY (getvar "CLAYER"))
          (if (= TASK "off")
            (progn
              (prompt (strcat "\nReally want layer " LAY " (the CURRENT layer) off? <N>: "))
              (setq ANS (strcase (getstring)))
              (if (not (or (= ANS "Y") (= ANS "YES")))
                (setq LAY nil)
            (progn
              (prompt (strcat "\nCannot freeze layer " LAY".  It is the CURRENT layer."))
              (setq LAY nil)
          (setq ANS nil)
        (if LAY
          (if (= TASK "off")
            (progn
              (if ANS
                (command "_.-LAYER" "_OFF" LAY "_Yes" "")
                (command "_.-LAYER" "_OFF" LAY "")
              (prompt (strcat "\nLayer " LAY " has been turned off."))
              (setq CNT (1+ CNT))
            (progn
              (command "_.-LAYER" "_FREEZE" LAY "")
              (prompt (strcat "\nLayer " LAY " has been frozen."))
              (setq CNT (1+ CNT))
; -------------- Nothing selected or Undo selected ---------------
      (progn
        (if (= EN "Undo")
          (if (> CNT 0)
            (progn
              (command "_.u")
              (setq CNT (1- CNT))
            (prompt "\nEverything has been undone.")
          (setq NOEXIT nil)
; --------------------- LAYER LOCK FUNCTION ----------------------
; Locks selected object's layer
(Defun C:TCK (/ LAY)
  (setq LAY (entsel "\nPick an object on the layer to be LOCKED: "))
  (if LAY
    (progn
      (setq LAY (cdr (assoc 8 (entget (car LAY)))))
      (Command "_.-LAYER" "_LOCK" LAY "")
      (prompt (strcat "\nLayer " LAY " has been locked."))
  (princ)
; -------------------- LAYER UNLOCK FUNCTION ---------------------
; Unlocks selected object's layer
(Defun C:TCU (/ LAY)
  (setq LAY (entsel "\nPick an object on the layer to be UNLOCKED: "))
  (if LAY
    (progn
      (Command "_.-LAYER" "_UNLOCK" LAY "")
      (prompt (strcat "\nLayer " LAY " has been unlocked."))
  (princ)
; ---------------------- LAYER ON FUNCTION -----------------------
; Turns all layers on
(Defun C:TCT ()
  (Command "_.-LAYER" "_ON" "*" "")
  (prompt "\nAll layers have been turned on.")
  (princ)
; --------------------- LAYER THAW FUNCTION ----------------------
; Thaws all layers
(Defun C:TCW ()
  (Command "_.-LAYER" "_THAW" "*" "")
  (prompt "\nAll layers have been thawed.")
  (princ)
; --------------------- LAYER MATCH FUNCTION ---------------------
; Changes the layer of selected object(s) to the layer of a
; selected destination object.
(Defun C:TCH (/ SS CNT LOOP LAY ANS)
    (progn
      (prompt "\nSelect objects to be changed: ")
      (setq SS (ssget))
  (if SS
    (progn
      (setq CNT (sslength SS))
      (princ (strcat "\n" (itoa CNT) " found."))      ; Report number of items found
      (command "_.move" SS "")                         ; filter out objects on locked layers
      (if (> (getvar "cmdactive") 0)                   ; if there are still objects left
        (progn
          (command "0,0" "0,0")
          (setq SS  (ssget "p")
                CNT (- CNT (sslength SS))              ; count them
        (setq SS nil)                                  ; else abort operation
      (if (> CNT 0)                                    ; if items where filtered out
        (if (= CNT 1)
          (princ (strcat "\n" (itoa CNT) " was on a locked layer."))   ; report it.
          (princ (strcat "\n" (itoa CNT) " were on a locked layer."))
  (if SS
    (progn
      (initget "Type")
      (setq LAY  (entsel "\nType name/Select entity on destination layer: ")
            LOOP T
      (while LOOP
        (cond
          ((not LAY)
            (prompt "\nNothing selected.")
            (prompt "\nUse current layer? <Y> ")
            (if (or (= ANS "") (= ANS "Y") (= ANS "YES"))
              (setq LAY  (getvar "clayer")
                    LOOP nil
          ((listp LAY)
            (setq LOOP nil)
          ((= LAY "Type")
            (setq LAY (getstring "\nEnter layer name: "))
            (cond
              ((tblobjname "LAYER" LAY)
                (setq LOOP nil)
              ((/= LAY "")
                (prompt "\nLayer does not exist. Would you like to create it? <Y>: ")
                  (if
                    (entmake (list
                              '(0 . "LAYER")
                              '(100 . "AcDbSymbolTableRecord")
                              '(100 . "AcDbLayerTableRecord")
                              '(6 . "CONTINUOUS")
                              '(62 . 7)
                              '(70 . 0)
                               (cons 2 LAY)
                    (setq LOOP nil)
                    (prompt "\nInvalid Layer name.")
        (if LOOP
          (progn
            (initget "Type")
            (setq LAY (entsel "\nType name/Select entity on destination layer: "))
      ); while LOOP
      (if (listp LAY)
      (command "_.change" SS "" "_p" "_la" LAY "")
      (if (= (sslength SS) 1)
        (prompt (strcat "\nOne object changed to layer " LAY ))
        (prompt (strcat "\n" (itoa (sslength SS)) " objects changed to layer " LAY ))
      (if (= LAY (getvar "clayer"))
        (prompt " (the current layer).")
        (prompt ".")
  (princ)
; --------------- CHANGE TO CURRENT LAYER FUNCTION ---------------
; Changes the layer of selected object(s) to the current layer
(Defun C:TCR (/ SS CNT LAY)
    (progn
      (prompt "\nSelect objects to be CHANGED to the current layer: ")
      (setq SS (ssget))
  (if SS
    (progn
        (progn
        (if (= CNT 1)
  (if SS
    (progn
        (prompt (strcat "\nOne object changed to layer " LAY " (the current layer)."))
        (prompt (strcat "\n" (itoa (sslength SS)) " objects changed to layer " LAY " (the current layer)."))
  (princ)
[/php]
发表于 2007-5-6 11:37:31 | 显示全部楼层
楼主如此用心,一定仔细试用你的软件,感谢
发表于 2016-8-15 18:10:33 | 显示全部楼层
:L:lol:lol
发表于 2018-1-15 14:04:12 | 显示全部楼层
谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享
GMT+8, 2026-11-2 22:51 , Processed in 0.538274 second(s), 40 queries , Gzip On.
