查看: 1124|回复: 3
[求助] [求助]:删除表中重复的元素用什么函数
发表于 2007-6-15 10:30:03 | 显示全部楼层 |阅读模式
删除表中重复的元素用什么函数?
发表于 2007-6-15 11:28:59 | 显示全部楼层
美女。。。一定没有搜过论坛里的贴子吧。
[php]
;;;删除列表中的相同元素(保留一个)并返回新表
(defun LstDelSame (lst / x nl)
  (foreach x lst
    (if        (not (member x nl))
      (setq nl (cons x nl))
  (reverse nl)
;;;N位開始,M 長度的子表
(defun LI_SubList ( Lst Start len / _len n m _Lst)
(if (minusp len)
    (setq len (1+(length lst)))
(setq
    _len (length Lst)
    n (min (- Start 1) _len)    ; Starting Index
    m (min (+ n len) _len)        ; Ending Index
    _Lst '()
(while (< n m)
    (setq
        _Lst (cons (nth n Lst) _Lst)
        n (1+ n)
(reverse _Lst)
;;;统计表中相同元素的个数
(defun lstsameitmnum (lst / a len x return)
(while lst
  (setq a (car lst))
  (setq len (length lst))
  (setq lst(vl-remove-if  '(lambda(x)(= a x)) lst))
  ;;第一个是(- len(length lst))个
  (setq return (cons (list a (- len(length lst))) return))
return
;;;两表的并集
(defun LSTUNION        (Lst1 Lst2 / Lst tmp)
  (append Lst1 lst2)
;;;两表的交集
(defun LSTINTER        (Lst1 Lst2 / Lst tmp lst11 lst22)
  (foreach tmp Lst2
    (if        (member tmp Lst1)
      (setq Lst22 (cons tmp Lst22))
  (foreach tmp Lst1
    (if        (member tmp Lst2)
      (setq Lst11 (cons tmp Lst11))
  (setq        Lst (append (reverse Lst11) (reverse Lst22))
        lst (LstDelSame lst)
  Lst
;;;两表的差集
(defun LSTDIFF (Lst1 Lst2 / Lst tmp lst11 lst22)
  (foreach tmp Lst2
    (if        (not (member tmp Lst1))
  (foreach tmp Lst1
    (if        (not (member tmp Lst2))
  Lst
;;;listremoveatom去除表delatom中指定的元素lstin
(defun listremoveatom (delatom lstin)
  (apply
    'append
    (subst
      nil
      (list delatom)
      (mapcar
    'list
    lstin
(defun LI_RemLst( itm lst / nlst elem len )
(setq nlst '())
(foreach elem lst
    (if (not (equal elem itm))
        (setq nlst (append nlst (list elem)))
nlst
;;;將表的第N項移去
(defun LI_DelLst( Idx Lst / nlst cnt elem )
(setq
    nlst '()
    cnt 1
(foreach elem lst
    (if (/= cnt Idx)
        (setq nlst (cons elem nlst))
    (setq cnt (1+ cnt))
(reverse nlst)
;;;及在表的第n項位置增加一元素
(defun LI_AddList (Lst Pos Val / Lst1 Lst2 cnt nverts )
(setq
    cnt 0
    Lst1 '()
    nverts (length Lst)
(repeat Pos
    (setq
        Lst1 (cons (nth cnt Lst) Lst1)
        cnt (1+ cnt)
(setq
    Lst1 (cons Val Lst1)
    Lst1 (reverse Lst1)
    cnt Pos
(if (> nverts Pos)
(progn
    (setq Lst2 '())
    (repeat (- nverts Pos)
        (setq
            Lst2 (cons (nth cnt Lst) Lst2)
            cnt (1+ cnt)
    (setq
        Lst2 (reverse Lst2)
        Lst1 (append Lst1 Lst2)
Lst1
;;;;表排序
;;;;(55 11 33 44 22 66) 变成(11 22 33 44 55 66)
;;;將表的第N項移去
(defun LI_DelLst (Idx Lst / nlst cnt elem)
  (setq
    nlst '()
    cnt         1
  (foreach elem        lst
    (if        (/= cnt Idx)
    (setq cnt (1+ cnt))
  (reverse nlst)
(defun sortlist (lis / len k abc nn len_nn plis)
  (setq len (length lis))
  (setq k 1)
  (while (<= k len)
    (setq abc (eval (append '(max) lis)))
    (setq nn 1)
    (setq len_nn (length lis))
    (while (<= nn len_nn)
      (if (= (nth (1- nn) lis) abc)
        (progn
          (setq lis (LI_DelLst nn lis))
          (setq plis (cons abc plis))
      (setq nn (1+ nn))
    (setq k (1+ k))
  (reverse plis)
[/php]
发表于 2007-6-17 07:46:29 | 显示全部楼层
试试这个: (acet-list-remove-duplicates plist tol)
其中: plist 表,tol 精度
已领礼包: 6个
发表于 2007-6-19 22:30:36 | 显示全部楼层
一般来说用的都是有序表~
再用这个方法来删相同元素就太慢了~
基本算法是:
如果表是有必要排序的
就先排序再用foreach来消重~
就算是不必要排序的表
如果有很多的要消重也要先排序再用foreach来消重
GMT+8, 2026-11-7 13:46 , Processed in 0.399472 second(s), 38 queries , Gzip On.
