查看: 1434|回复: 0
[求助] [求助]:各位大大帮帮忙
发表于 2007-9-27 09:46:57 | 显示全部楼层 |阅读模式
各位大大帮帮忙,下面lisp在2002时用没问题,为何在autocad 2005中改属性文字时,却无法修改,且出现" 错误: ActiveX 伺服器回覆一个错误讯息: 载入类型程式库/DLL 时发生错误。"的字样呢
;; 命令:EDIT_TXT
;; 功能:改块文字、属性、多行文字 、标注文字
(defun C:EDIT_TXT (/ ENT TYPE_NAME TMP_TXT SEL)
  (vl-load-com)
  (defun DO_IT ()
    (entmake (list '(0 . "TEXT")
     '(100 . "AcDbEntity")
     '(100 . "AcDbText")
     '(60 . 1)
     '(10 0.0 0.0 0.0)
     '(40 . 0.000000001)
     (cons 1 (cdr (assoc 1 (entget ENT))))
    (setq TMP_TXT (entlast))
    (command "_.DDEDIT" TMP_TXT "")
    (vla-put-textstring
      (vlax-ename->vla-object ENT)
      (cdr (assoc 1 (entget TMP_TXT)))
    (entdel TMP_TXT)
  (princ "\n ***** 可修改│属性文字│标注文字│图块内文字│*****")
  (if (setq SEL (nentsel "\n 选择文字=>"))
    (progn
      (setq ENT (car SEL))
      (setq TYPE_NAME (cdr (assoc 0 (entget ENT))))
      (cond
((and (= TYPE_NAME "TEXT") (= (length SEL) 4))
  (DO_IT)
  (command "_.REGEN")
((wcmatch TYPE_NAME "TEXT,MTEXT,ATTDEF")
  (if (and (equal TYPE_NAME "MTEXT") (= (length SEL) 4))
    (setq ENT (car (last SEL)))
  (command "_.DDEDIT" ENT "")
((= TYPE_NAME "ATTRIB") (DO_IT))
  (princ)
GMT+8, 2026-11-22 09:08 , Processed in 0.362352 second(s), 10 queries , Gzip On, File On.
