查看: 1504|回复: 1
[讨论]文字裁切双位元函数
发表于 2007-10-12 20:34:55 | 显示全部楼层 |阅读模式
[讨论]文字裁切双位元函数
或许已有高手编写过了,但因为没有找到过
所以编写了这支可以切断文字左边或右边的函数,
想请各位高手多多指导精简一下,
并看看是否还有其他要改进的地方.
谢谢~
(SETQ STR "一二三四五") ;字串
(SETQ STR_ST 3)  ;字串起始值 1...
(SETQ STR_LH 3)  ;字串切割位数 1...N / NIL
(SETQ DB_Byte T) ;双位元计算保留 T/NIL
(SETQ CP_LF T)   ;反转左切 T/NIL
(JTHWA-TRIM-STR STR STR_ST STR_LH DB_Byte CP_LF)
exp1:
(SETQ STR "1234567890")
(JTHWA-TRIM-STR STR 3 1 t t)
_$ "3"
(JTHWA-TRIM-STR STR 3 2 n t)
_$ "23"
(JTHWA-TRIM-STR STR 3 1 n n)
_$ "3"
(JTHWA-TRIM-STR STR 3 2 n n)
_$ "34"
exp2:
(SETQ STR "一二三四五")
_$ "二"
(JTHWA-TRIM-STR STR 3 3 n n)
_$ "二?
(JTHWA-TRIM-STR STR 3 3 t n)
_$ "二三"
(JTHWA-TRIM-STR STR 4 3 t n)
_$ "二三"
(JTHWA-TRIM-STR STR 4 4 t n)
_$ "二三四"
(JTHWA-TRIM-STR STR 4 4 n t)
_$ "一二"
(JTHWA-TRIM-STR STR 4 3 n t)
_$ "@二"
(JTHWA-TRIM-STR STR 5 2 t t)
_$ "二三"
(JTHWA-TRIM-STR STR 7 3 t t)
_$ "三四"
[PHP]
(DEFUN JTHWA-TRIM-STR (STR STR_ST STR_LH DB_Byte CP_LF / ANS I ST01
                           ST02 STAL STNNB STR_LH-BK STR_LH-FT STR_LH-K
                           STR_LH-ME STR_ST-BK STR_ST-FT STR_ST-ME
                           STR_STLH SUBNB-K TSTNB )
  (SETQ STNNB NIL)
  (SETQ STAL (tc:getstrwid STR))
  (SETQ ST01 (CAR (tc:getstrwid STR)))
  (SETQ ST02 (CDR (tc:getstrwid STR)))
  (SETQ I -1)
  (REPEAT ST01
    (SETQ I (1+ I))
    (SETQ TSTNB (strlen (NTH I ST02)))
    (REPEAT TSTNB
      (SETQ STNNB (CONS I STNNB))
  (SETQ STNNB (reverse STNNB))
  (IF CP_LF
    ;; ======================处理左切字串
    (PROGN
      (SETQ STR_STLH (strlen STR))
      (SETQ SUBNB-K (1- STR_ST))
      (SETQ STR_ST-FT (IF (minusp (1+ SUBNB-K))
                        NIL
                        (NTH (1+ SUBNB-K) STNNB)
      (SETQ STR_ST-ME (IF (minusp (NTH SUBNB-K STNNB))
                        NIL
                        (NTH SUBNB-K STNNB)
      (SETQ STR_ST-BK (IF (minusp (1- SUBNB-K))
                        NIL
                        (NTH (1- SUBNB-K) STNNB)
      (COND
        ((OR
           (= SUBNB-K 0)
           (minusp STR_ST)
           (< STR_ST STR_LH)
          (PRINT "Runner Error")
          (SETQ ANS "")
        (T
          (IF DB_Byte
            (PROGN
              (IF (= STR_LH NIL)
                (SETQ STR_LH (1- STR_ST))
              (COND
                ((= STR_ST-ME STR_ST-FT)
                  (SETQ STR_ST (1+ STR_ST))
                  (SETQ STR_LH (1+ STR_LH))
                ((= STR_ST-ME STR_ST-BK)
                  (SETQ STR_ST STR_ST)
              (IF STR_LH
                (PROGN
                  (SETQ STR_LH-K (- STR_ST STR_LH))
                  (SETQ STR_LH-FT (IF (minusp (1+ STR_LH-K))
                                    NIL
                                    (NTH (1+ STR_LH-K) STNNB)
                  (SETQ STR_LH-ME (IF (minusp (NTH STR_LH-K STNNB))
                                    NIL
                  (SETQ STR_LH-BK (IF (minusp (1- STR_LH-K))
                                    NIL
                                    (NTH (1- STR_LH-K) STNNB)
              (IF STR_LH
                (PROGN
                  (COND
                    ((= STR_LH-ME STR_LH-FT)
                      (SETQ STR_LH STR_LH)
                    ((= STR_LH-ME STR_LH-BK)
                  (SETQ ANS (SUBSTR STR (1+ (- STR_ST STR_LH)) STR_LH))
                (SETQ ANS (SUBSTR STR 1 STR_ST))
            (PROGN
              (IF STR_LH
                (SETQ ANS (substr STR (SETQ STR_ST (- (1+ STR_ST)
                                                      STR_LH
                (SETQ ANS (substr STR 1 STR_ST))
    ;; ======================处理右切字串
    (PROGN
      (SETQ STR_ST-FT (IF (minusp STR_ST)
                        NIL
                        (NTH STR_ST STNNB)
                        NIL
                        (NTH SUBNB-K STNNB)
                        NIL
      (COND
        ((OR
           (= SUBNB-K 0)
           (minusp STR_ST)
           (> SUBNB-K STR_STLH)
          (SETQ ANS "")
        (T
          (IF DB_Byte
            (PROGN
              (COND
                  (SETQ STR_ST (1- STR_ST))
                  (SETQ STR_LH (IF (= STR_LH NIL)
                                 (SETQ STR_LH NIL)
                                 (1+ STR_LH)
              (IF (= STR_LH NIL)
                (SETQ STR_LH NIL)
                (IF STR_LH
                  (PROGN
                    (SETQ STR_LH-K (- (+ STR_ST STR_LH) 2))
                                      NIL
                                      NIL
                                      NIL
              (IF STR_LH
                (PROGN
                  (COND
                  (SETQ ANS (SUBSTR STR STR_ST STR_LH))
                (SETQ ANS (SUBSTR STR STR_ST))
            (PROGN
              (IF STR_LH
                (SETQ ANS (substr STR STR_ST STR_LH))
                (SETQ ANS (substr STR STR_ST))
  (PRINT ANS)
  (prin1)
tc:getstrwid 函数
引用来源: http://www.mjtd.com/bbs/dispbbs. ... ID=50326&page=1
BY xxsheng
(defun tc:getstrwid(str / m n a c)
  (setq m 0)
  (setq n 0)
  (while (< m (strlen str))
    (if (> (vl-string-elt str m) 128)
      (progn
        (setq n(1+ n))
    (setq a (substr str (1+ m) 2))
    (setq m(+ 2 m))
      (progn
    (setq n(1+ n))
    (setq a (substr str (1+ m) 1))
    (setq m(1+ m))
    (setq c(cons a c))
  (setq c(reverse c))
  (cons n c)
[/PHP]
发表于 2007-10-12 22:58:39 | 显示全部楼层
把 Substr 搞这么复杂!
GMT+8, 2026-11-22 11:15 , Processed in 0.261803 second(s), 12 queries , Gzip On, File On.
