查看: 3707|回复: 1
[求助]:我拿到ADT2006繁版装
发表于 2007-10-22 00:34:46 | 显示全部楼层 |阅读模式
我在安裝Autodesk Architectural Desktop 2006時出了問題,無法完成安裝,想請教是否那裡有問題?
我的做業系統是 XP-PRO-SP2
顯示安裝的訊息:
[6/24/2007 00:18:32] === Installation started on E-XXXXXXXXXXXXXXXX by xxx ===
[6/24/2007 00:18:37] [Info] Windows Installer upgrade is not required
[6/24/2007 00:18:37]   System Version = 3.1.4000.2435
[6/24/2007 00:18:37] Installation skipped: MSI Runtime 3.0
[6/24/2007 00:18:37] [Info] .NET Framework Runtime upgrade is not required
[6/24/2007 00:18:37]   System Version = 2.0.50727.42
[6/24/2007 00:18:37] Installation skipped: .NET Framework Runtime 1.1
[6/24/2007 00:18:37] Installation started: .NET Framework Runtime 1.1 Language Pack
[6/24/2007 00:18:37]   Command = "F:\ADT\support\dotnetfx\cht\langpack.exe" /q:a /c:"inst /qb"
[6/24/2007 00:18:46] Installation succeeded: .NET Framework Runtime 1.1 Language Pack
[6/24/2007 00:18:46] [Info] .NET Framework Runtime upgrade is not required
[6/24/2007 00:18:46]   System Version = 2.0.50727.42
[6/24/2007 00:18:46] Installation skipped: .NET Framework Runtime 1.1 SP1
[6/24/2007 00:18:47] [Info] MDAC upgrade is not required
[6/24/2007 00:18:47]   System Version = 2.81.1117.0
[6/24/2007 00:18:47] Installation skipped: MDAC 2.7
[6/24/2007 00:18:47] Installation started: Autodesk DWF Viewer
[6/24/2007 00:18:47]   Command = "F:\ADT\support\aev\DwfViewerSetup.exe" /u2 /q2
[6/24/2007 00:18:48] [Error: 11] 試圖載入格式錯誤的程式。
[6/24/2007 00:18:48] Installation failed: Autodesk DWF Viewer
[6/24/2007 00:18:48] [Info] Failure is ignored
[6/24/2007 00:18:48] Installation started: Flash
[6/24/2007 00:18:48]   Command = "F:\ADT\support\flash\Silent Install Flash Player 7 AX.exe" /q
[6/24/2007 00:18:51] [Error: 1] 功能錯誤。
[6/24/2007 00:18:51] Installation failed: Flash
[6/24/2007 00:18:51] [Info] Failure is ignored
[6/24/2007 00:18:51] Installation started: Autodesk Architectural Desktop 2006
[6/24/2007 00:18:51]   Command = msiexec /i "F:\ADT\adt.msi" /L*v C:\DOCUME~1\SJY\LOCALS~1\Temp\adtInstall.log
[6/24/2007 00:30:00] [Error: 1603] 安裝時發生嚴重錯誤。
[6/24/2007 00:30:00] Installation failed: Autodesk Architectural Desktop 2006
[6/24/2007 00:30:00] Installation aborted
[6/24/2007 00:30:06] === Installation ended ===
有高人說是cd 1下載不全,請問有人願提供cd 1嗎?
发表于 2009-8-7 23:32:14 | 显示全部楼层
繁体的啊?我上次下了好久都没下下来。遗憾啊。
GMT+8, 2026-11-22 07:36 , Processed in 0.203151 second(s), 10 queries , Gzip On, File On.
