查看: 1388|回复: 3
[分享]:F#开发语言
发表于 2007-12-4 16:21:23 | 显示全部楼层 |阅读模式
Here's some code F# that goes through the modelspace and paperspace of the current drawing inside AutoCAD, and prints a list of all the distinct words used inside the various MText objects:
  1.   [FONT=courier new]
  2. // Use lightweight F# syntax
  3. #light
  4. (* Declare a specific namespace
  5.   and module name
  6. *)
  7. module MyNamespace.MyApplication
  8. // Import managed assemblies
  9. #I @"C:\Program Files\Autodesk\AutoCAD 2008"
  10. #r "acdbmgd.dll"
  11. #r "acmgd.dll"
  12. open System
  13. open System.Collections.Generic
  14. open Autodesk.AutoCAD.Runtime
  15. open Autodesk.AutoCAD.ApplicationServices
  16. open Autodesk.AutoCAD.DatabaseServices
  17. // Now we declare our command
  18. [<CommandMethod("Words")>]
  19. let listWords () =
  20.   // Let's get the usual helpful AutoCAD objects
  21.   let doc =
  22.     Application.DocumentManager.MdiActiveDocument;
  23.   let ed = doc.Editor;
  24.   let db = doc.Database;
  25.   // "use" has the same effect as "using" in C#
  26.   use tr =
  27.     db.TransactionManager.StartTransaction();
  28.   // Get appropriately-typed BlockTable and BTRs
  29.   let bt =
  30.     tr.GetObject
  31.       (db.BlockTableId,OpenMode.ForRead)
  32.     :?> BlockTable
  33.   let ms =
  34.     tr.GetObject
  35.       (bt.[BlockTableRecord.ModelSpace],
  36.       OpenMode.ForRead)
  37.     :?> BlockTableRecord
  38.   let ps =
  39.     tr.GetObject
  40.       (bt.[BlockTableRecord.PaperSpace],
  41.       OpenMode.ForRead)
  42.     :?> BlockTableRecord
  43.   // Now the fun starts...
  44.   // A function that accepts an ObjectId and returns
  45.   // a list of the text contents, or an empty list.
  46.   // Note the valid use of tr, as it is in scope
  47.   let extractText (x : ObjectId) =
  48.     let obj = tr.GetObject(x,OpenMode.ForRead);
  49.     match obj with
  50.     | :? MText -> [(obj :?> MText).Contents];
  51.     | _ -> []
  52.   // A recursive function to print the contents of a list
  53.   let rec printList x =
  54.     match x with
  55.     | h :: t -> ed.WriteMessage("\n" + h); printList t
  56.     | [] -> ed.WriteMessage("\n")
  57.   // Partial application of split which can then be
  58.   // applied to a string to retrieve the contained words
  59.   let words = String.split [' ']
  60.   // And here's where we plug everything together...
  61.   Seq.untyped_to_list ms @ Seq.untyped_to_list ps |>
  62.     List.map extractText |> List.flatten |> List.map words |>
  63.     List.flatten |> Set.of_list |> Set.to_list |> printList
  64.   // As usual, committing is cheaper than aborting
  65.   tr.Commit()
  66.   [/FONT]
F#的下载地址 http://research.microsoft.com/fsharp/release.aspx
F#的一些例子 http://www.codeplex.com/fsharpsamples
发表于 2007-12-4 17:44:39 | 显示全部楼层
binbin, 不打开dwg文件能在后台打印出文件里的内容吗,我试了一下打印预览不能显示出图形来,都是空白.
是不是打印必须要打开文件啊?
发表于 2007-12-5 09:20:38 | 显示全部楼层
 楼主| 发表于 2007-12-5 10:16:15 | 显示全部楼层
  2. #import "acad.tlb" no_namespacevoid
  3. fTest()
  4. {
  5.         // Use ActiveX interface to get the application object
  6.         IAcadApplicationPtr pAcad = acedGetAcadWinApp()->GetIDispatch(TRUE);
  7.         //get the path to plotter configuration
  8.         _bstr_t szPrinterPath;
  9.         szPrinterPath = pAcad->Preferences->GetFiles()->GetPrinterConfigPath() + _bstr_t("\\DWF ePlot (optimized for plotting).pc3");
  10.         // get the current database
  11.         AcDbDatabase *curDocDB = acdbHostApplicationServices()->workingDatabase();
  12.         // get a pointer to the layout manager
  13.         AcApLayoutManager *pLayoutManager = (AcApLayoutManager *)acdbHostApplicationServices()->layoutManager();
  14.         const char *layoutName = pLayoutManager->findActiveLayout (true);
  15.         // get the current layout
  16.         AcDbLayout *pLayout = pLayoutManager->findLayoutNamed (layoutName, true);
  17.         // if we got it ok
  18.         if (pLayout != NULL)
  19.         {
  20.                 Acad::ErrorStatus es;
  21.                 // get the plotsetttings class
  22.                 AcDbPlotSettingsValidator *pPlotSettingsValidator = acdbHostApplicationServices()->plotSettingsValidator();
  23.                 // if we got it ok
  24.                 if (pPlotSettingsValidator != NULL)
  25.                 {
  26.                         // Refresh the layout lists in order to use it
  27.                         pPlotSettingsValidator->refreshLists (pLayout);
  28.                         // change the current layout plotter
  29.                         es = pPlotSettingsValidator->setPlotCfgName (pLayout, szPrinterPath);
  30.                         // set the window to plot as the extents of the drawing
  31.                         es = pPlotSettingsValidator->setPlotWindowArea (pLayout,curDocDB->extmin ().x,curDocDB->extmin ().y,curDocDB->extmax ().x,curDocDB->extmax ().y);
  32.                         // set the orgin
  33.                         es = pPlotSettingsValidator->setPlotOrigin (pLayout,curDocDB->extmin ().x,curDocDB->extmin ().y);
  34.                         // set to plot centred
  35.                         es = pPlotSettingsValidator->setPlotCentered (pLayout, true);
  36.                         // setup the plot type to window
  37.                         es = pPlotSettingsValidator->setPlotType (pLayout, AcDbPlotSettings::kWindow);
  38.                         // set the scale
  39.                         es = pPlotSettingsValidator->setStdScaleType (pLayout, AcDbPlotSettings::StdScaleType::kScaleToFit);
  40.                         // we have to close the layout here because the last parameter of
  41.                         // findLayoutNamed is true, leave layout open
  42.                         pLayout->close ();
  43.                 }
  44.         }  // get the current document
  45.         IAcadDocumentPtr pDoc = pAcad->GetActiveDocument();
  46.         // create a plot object
  47.         IAcadPlotPtr pPlot = pDoc->GetPlot();
  48.         // lets plot
  49.         pPlot->PlotToFile("c:\\test.dwf", szPrinterPath);
  50. }
  51.   [/FONT]
GMT+8, 2026-11-4 07:25 , Processed in 0.619696 second(s), 38 queries , Gzip On.
