查看: 2053|回复: 2
[LISP函数]:几个字符串处理函数,请大家提意见
发表于 2007-12-14 08:22:43 | 显示全部楼层 |阅读模式
;;;;提取字串中的数字,lst ( "+" ".") 需要当作数字处理的符号
(defun zgx-find-num (str lst / rtn-str rtn-str1 lst) ;rtn-str)
    (setq rtn-str ""
          rtn-str1 ""
          lst nil
    (while (/= str "")
        (if (zgx-singlestr-if-num (zgx-substr str 1 1) lst)
            (progn
                (setq rtn-str (strcat rtn-str (zgx-substr str 1 1))
                      str     (zgx-substr str 2 0)
                (while (zgx-singlestr-if-num (zgx-substr str 1 1) lst)
                (setq lst (append lst (list rtn-str)))
                (setq rtn-str "")
            (progn
                (setq rtn-str1 (zgx-substr str 1 1)
                (while
                    (and
                        (not (zgx-singlestr-if-num (zgx-substr str 1 1)
                                                   lst
                        (/= str "")
                       (setq rtn-str1 (strcat rtn-str1
                (setq lst (append lst (list rtn-str1)))
                (setq rtn-str1 "")
    lst
;;-----判断是否为英文字符----------------
(defun zgx-singlestr-if-letter (str)
    (if        (wcmatch str (strcat str "*"))
        t
        nil
;;;-----判断单个字母是否为数字,lst ( "+" ".") 需要当作数字处理的符号------
(defun zgx-singlestr-if-num (str lst)
    (if        (or
            (wcmatch str "#")
            (member str lst)
        t
        nil
;;;---判断整个单词是否为数字,lst ( "+" ".") 需要当作数字处理的符号----------
(defun zgx-wholestr-if-num (str lst / yes)
    (setq yes t)
    (while (and
               (/= "" str)
               yes
            (setq str (zgx-substr str 2 1))
            (setq yes nil)
    yes
;;------字符串长度,汉字按一个字符计算------------------
(defun zgx-strlen (str / m n)
    (setq m 0)
    (while (/= str "")
        (if (zgx-singlestr-if-letter (substr str 1 1))
            (setq n 1)
            (setq n 2)
        (setq str (substr str (+ 1 n)))
        (setq m (1+ m))
    m
;;-------取代substr,汉字按一个字符计算,n<0 则substr str m,否则substr m n-----------------
(defun zgx-substr (str m n / mm nn teststr kk str1)
    (if        (= m 0)
        (setq str1 str)
        (progn
            (setq mm 0
                  nn 0
            (repeat (- m 1)
                (if (and
                        str
                        (/= "" str)
                    (progn
                        (setq teststr (substr str 1 1))
                        (if (zgx-singlestr-if-letter teststr)
                            (setq kk 1)
                            (setq kk 2)
                        (setq mm (+ mm kk))
                        (setq str (substr str (1+ kk)))
            (setq str1 str)
            (repeat n
                (if (and
                        str
                        (/= "" str)
                    (progn
                            (setq kk 1)
                            (setq kk 2)
                        (setq nn (+ nn kk))
            (if        (> n 0)
                (substr str1 1 nn)
                (substr str1 1)
发表于 2009-10-22 16:18:16 | 显示全部楼层
好,有实力。下载学习你的经验
发表于 2014-9-1 20:19:14 | 显示全部楼层
正好用到,感谢!
GMT+8, 2026-11-22 11:08 , Processed in 0.367602 second(s), 14 queries , Gzip On, File On.
