查看: 980|回复: 0
[求助]:请大家指点一段程序
发表于 2008-2-18 13:04:04 | 显示全部楼层 |阅读模式
这是一段绘制双线管道的程序,如下:
(defun c:gd ()
  (defun zgd (bpoint epooint / bp1 bp2 ep1 ep2)
    (if    (= (cadr bpoint) (cadr epoint))
      ;;固定bp1和ep1的位置,水平在其上侧,垂直在其左侧
      (progn
    (setq bp1 (polar bpoint (/ pi 2) gdr))
    (princ bp1)
    (setq bp2 (polar bpoint (- (/ pi 2)) gdr))
    (princ bp2)
    (setq ep1 (polar epoint (/ pi 2) gdr))
    (princ ep1)
    (setq ep2 (polar epoint (- (/ pi 2)) gdr))
    (princ ep2)
    (if    (= (car bpoint) (car epoint))
      (progn
    (setq bp1 (polar bpoint pi gdr))
    (princ bp1)
    (setq bp2 (polar bpoint 0 gdr))
    (princ bp2)
    (setq ep1 (polar epoint pi gdr))
    (princ ep1)
    (setq ep2 (polar epoint 0 gdr))
    (princ ep2)
    (command "-linetype" "s" "center" "")
    (command "line" bpoint epoint "")
    (command "-linetype" "s" "continuous" "")
    (command "pline" bp1 ep1 "")
    (command "pline" bp2 ep2 "")
    (command "line" bp1 bp2 "")
    (command "line" ep1 ep2 "")
  (print "双线管道绘制程序:α版")
  (print
    "目前此程序只绘制垂直或水平带90度弯头的管道,第一段管道必须为直管段"
  (print "二个弯头不能直接相连,必须有一段直管段")
  (setq mysnap (getvar "osmode"))
  (princ mysnap)
  (setq myortho (getvar "orthomode"))
  (setq xk (getvar "plinewid"))
  (setvar "osmode" 0)
  (setq sc (getint "请输入图形比例: 1: "))
  (setq gdd (getint "请输入管道直径: "))
  (setq gdr (/ (* 0.5 gdd) sc))
  ;;管道图中真实径
  (setq gdxk (getreal "输入双线线宽"))
  (setq wtd(getreal "输入弯头大小,几倍D"))
  (setvar "plinewid" gdxk)
  (setq bpoint (getpoint "请输入起始点: "))
  (setvar "orthomode" 1)
  (setq epoint (getpoint bpoint "输入下一点:"))
  (princ epoint)
  (zgd bpoint epoint)
  (setq lsd bpoint)            ;临时点储存原始端点
  (setq bpoint epoint)
  (setq n 1.0)
  (while (> n 0.0)
    (setq zl (getint "选择绘制种类:1、直管段;2、弯头:"))
    (princ zl)
    (if    (= zl 1)
    (if    (= zl 2)
      (setvar "orthomode" 0)
    (setq emang (angle bpoint epoint))    ;直线度
    (princ emang)
    (while (= zl 1)
      (zgd bpoint epoint)
      (setq zl 0)
    (while (= zl 2)
      (if (and (= (cadr bpoint) (cadr lsd)) (> emang 0) (< emang pi))
    (progn
      (if (> (car bpoint) (car lsd))
        (progn
          (setq emang (/ pi 4))
          (setq emang2 (/ pi 8))
      (if (< (car bpoint) (car lsd))
        (progn
          (setq emang (* pi 0.75))
          (setq emang2 (* pi 0.875))
      (setq epoint (polar bpoint emang (* gdr (sqrt(* 8 wtd  wtd )))))
      (setq mpoint (polar bpoint emang2 (* gdr 4 wtd (sin (/ pi 8)))))
      (if (and (= (cadr bpoint) (cadr lsd)) (> emang pi))
    (progn
        (progn
          (setq emang (- (/ pi 4)))
          (setq emang2 (- (/ pi 8)))
        (progn
          (setq emang (- (* pi 0.75)))
          (setq emang2 (- (* pi 0.875)))
      (setq epoint (polar bpoint emang (* gdr (sqrt(* 8 wtd wtd)))))
      (if (and (= (car bpoint) (car lsd))
           (> (car epoint) (car bpoint))
      )                ;管道为垂直,弯头在右侧
    (progn
      (if (< (cadr lsd) (cadr bpoint)) ;管道向上
        (progn
          (setq emang2 (* pi 0.375))
      (if (> (cadr lsd) (cadr bpoint)) ;管道向下
        (progn
          (setq emang2 (- (* pi 0.375)))
      (princ emang)
      (setq epoint (polar bpoint emang (* gdr (sqrt (* 8 wtd wtd)))))
           (< (car epoint) (car bpoint))
    (progn
        (progn
          (setq emang2 (* pi 0.625))
      (if (< (cadr bpoint) (cadr lsd))
        (progn
          (setq emang2 (- (* pi 0.625)))
                    ; (princ "YYYY YYYY")
      (command "arc" bpoint mpoint epoint "")
      (command "pline" bpoint "a" "s" mpoint epoint "")
      (setq ss (ssget "L"))
      (setq lsda (list (car bpoint) (cadr epoint) 0))
      (command "offset" gdr ss lsda "")
      (setq lsdb (list (car epoint) (cadr bpoint) 0))
      (command "offset" gdr ss lsdb "")
      (command "erase" ss "")
      (setq zl 0)
    (setq bpoint epoint)        ;转换始点,点
    (setq x (getint "是否结束绘制:1、继续;2、结束"))
    (princ x)
    (if    (= x 2)
      (setq n 0.0)
  (setvar "PLINEWID" xk)
  (setvar "OSMODE" mysnap)
  (setvar "orthomode" myortho)
当提示输入管道直径时,输入直径就提示错误,请高手修改,不胜感激!!!谢谢!
GMT+8, 2026-11-3 20:45 , Processed in 0.667486 second(s), 32 queries , Gzip On.
