查看: 1031|回复: 3
[求助] [求助]:为何不能打断PT1 PT2之间的线段
发表于 2008-4-1 21:01:14 | 显示全部楼层 |阅读模式
;;;--------墙线----------
(defun C:WLL (/ L1 L2 PT1 PT2 PT3 PT4 KU)
    (if        (setq L1 (getpoint "\nPick point:"))
        (progn
            (setq OLD_CMDECHO (getvar "CMDECHO"))
            (setvar "CMDECHO" 0)
            (setq CL (getvar "clayer"))
            (setvar "EDGEMODE" 1)
            (command "-layer" "m" "WALL" "C" "31" "" "")
            ;;PLINEWID 存储多段线的缺省宽度
            (setvar "PLINEWID" 60)
            (while (setq L2 (getpoint L1 "\nPick point:"))
                (setq KU (angle L1 L2))
                (setq PT1 (polar L1 (+ KU (* 0.5 pi)) 120))
                (setq PT2 (polar L1 (+ KU (* 1.5 pi)) 120))
                (setq PT3 (polar L2 (+ KU (* 0.5 pi)) 120))
                (setq PT4 (polar L2 (+ KU (* 1.5 pi)) 120))
                ;;绘制
                (command "_.Pline" "non" PT1 "non" PT3 "")
                (command "_.Pline" "non" PT2 "non" PT4 "")
                ;;打断
                (command "break" "non" L1 "f" "non" PT1 "non" PT2)
                (command "break" "non" L2 "f" "non" PT3 "non" PT4)
            (setvar "clayer" CL)
            (setvar "CMDECHO" OLD_CMDECHO)
    (princ)
图中原有二条平行线。执行上面的程序,L1 L2分别在二条平行线上,程序执行后,为何不能打断PT1 PT2之间的线段
发表于 2008-4-1 21:20:56 | 显示全部楼层
break好像是不能这样联系执行的?
 楼主| 发表于 2008-4-1 21:44:48 | 显示全部楼层
那应如何执行?
发表于 2008-4-3 20:20:30 | 显示全部楼层
联系ljttjl@tom.com,帮您解决
GMT+8, 2026-11-7 08:51 , Processed in 0.411328 second(s), 38 queries , Gzip On.
