查看: 1840|回复: 7
[LISP程序]:一个波浪线的程序,请大家完善!
已领礼包: 2个
发表于 2008-4-4 17:54:35 | 显示全部楼层 |阅读模式
尚缺以下功能:
1、只能从左往右,想增加交换顶点的if程序,增加成功了,不够完美;
2、设定比例,想增加的朋友自己增加;
3、画完的多义线无法连成一条线,自己增加语句,未果;
4、取消了任意角度,只能水平画线。
以上1、3请求达人帮忙!
基本可以使用的哦^_^,需要完善!
[PHP]
Water.LSP (c)2008
(defun newerr (NE)
   (if (/= NE "Function cancelled")
      (princ (strcat "\nError: " NE))
   (setvar "OSMODE" OM)
   (setvar "CMDECHO" CE)
   (setvar "BLIPMODE" BM)
   (command "layer" "m" "water" "c" "1" "water" "")
   (princ)
(defun c:water
   (/ SP EP HT OM CE BM DX AN NX NU AX PX
         P1 P2 P3 P4 P5 XSP XEP XT tmpep tmpsp)
   (while (= SP nil) (setq SP
         (getpoint "\nPick start point of water: ")))
   (while (= EP nil) (setq EP
         (getpoint "\nPick end point of water: ")))
   (setq OM (getvar "OSMODE")) (setvar "OSMODE" 0)
   (setq CE (getvar "CMDECHO")) (setvar "CMDECHO" 0)
   (setq BM (getvar "BLIPMODE")) (setvar "BLIPMODE" 0)
   (setq orth (getvar "orthomode")) (setvar "orthomode" 0)
   (setq XSP (car SP) XEP (car EP))
   (if (> XSP XEP)
       (progn
       (setq tmpsp SP)
       (setq tmpep EP)
       (setq SP tmpep)
       (setq EP tmpsp)
     (setq DX (distance SP EP)
      AN (angle SP EP)
      NU (/ DX 100)
      AX (+ AN (/ pi 2))
      P1 (list (+ 20 (car SP)) (- (cadr SP) 20))
      P2 (list (+ 40 (car SP)) (- (cadr SP) 30))
      P3 (list (+ 60 (car SP)) (- (cadr SP) 30))
      P4 (list (+ 80 (car SP)) (- (cadr SP) 20))
      P5 (polar SP 0 100)
      (repeat (fix NU)
      (command ".PLINE" SP P1 P2 P3 P4 P5 "")
      (command ".pedit" "m" "l" "" "j" 0 "")
      (setq SP P5
      P5 (polar SP 0 100)
   (setvar "orthomode" orth)
   (princ)
);end
[/PHP]
已领礼包: 12496个
发表于 2008-4-5 10:08:16 | 显示全部楼层
[php]
(defun c:water (/ SP EP HT OM CE BM DX AN NX NU AX PX
(IF (AND (setq SP (getpoint "\nPick start point of water: "))
          (setq EP (getpoint SP "\nPick end point of water: "))) (PROGN
  (if (> XSP XEP) (setq tmpsp SP tmpep EP SP tmpep EP tmpsp))
  (setq NU (/ (distance SP EP) 100)
          AN (angle SP EP)
          P1 (polar SP AN 100))
  (COMMAND ".PLINE" SP "A" "A" "125" P1)
  (repeat (fix NU)
   (setq P1 (polar P1 AN 100))
   (COMMAND "A" "125" P1)
  (COMMAND "")
(princ)
);end
[/php]
发表于 2008-4-6 09:53:30 | 显示全部楼层
用一下
已领礼包: 2个
 楼主| 发表于 2008-4-6 11:24:55 | 显示全部楼层
zxq0220
请问一下,我要生成五段多义线,可以么?
已领礼包: 12496个
发表于 2008-4-6 14:21:01 | 显示全部楼层
是五条波浪线吗?线的间隔是多少?
已领礼包: 2个
 楼主| 发表于 2008-4-7 01:43:24 | 显示全部楼层
我的意思是说每个单元都是五个线段,每段的水平距离是20,垂直距离是20,10,0,所以编写起来有点难度,可能需要使用两个循环语句,所以有点晕了!
已领礼包: 12496个
发表于 2008-4-8 20:10:18 | 显示全部楼层
可以用子程序。
[php]
(defun newerr (NE)
(princ)
  (setq AN (angle SP EP))
  (wave SP AN 5)
  (wave (polar (polar sp (+ (/ pi 2) AN) 10) AN 20) AN 5)
  (wave (polar (polar sp (+ (/ pi 2) AN) 20) AN 40) AN 5)
(princ)
);end
(defun wave (pt1 ang n / p1)
(setq P1 (polar SP ang 100))
(COMMAND ".PLINE" pt1 "A" "A" "125" P1)
(repeat (fix N)
  (setq P1 (polar P1 ang 100))
(COMMAND "")
[/php]
已领礼包: 2个
 楼主| 发表于 2008-4-9 00:41:43 | 显示全部楼层
学习了,不过我用做选择集的方法已经搞出来了,o(∩_∩)o
谢谢你哟,你的方法还是有问题,有空多指教!
我作的选择集
[PHP]
(setq ST SP)
(setq EN (polar SP (ANGLE SP EP) (DISTANCE SP EP)))
(setq ss1 (ssget "C" (list (- (car ST) 1) (- (cadr ST) 101)) (list (+ (car EN) 1) (+ (cadr EN) 101))))
(command ".pedit" "m" ss1 "" "J" 0.1 "" )
[/PHP]
GMT+8, 2026-11-7 08:52 , Processed in 0.521146 second(s), 45 queries , Gzip On.
