查看: 1160|回复: 1
[求助] [求助]:这个lisp为什么没办法用呢?
发表于 2008-5-18 20:24:37 | 显示全部楼层 |阅读模式
(defun _join1 (str / e na)
  (while (and (setq e (gete str))
              (getent (car e))
              (not (TgWcMatch (setq na (socas 0)) "LINE,ARC"))
    (print)
    (princ
      (strcat "\n*** 已拾取了'" na "', 请拾取'LINE'或'ARC'!")
  e
(defun c:wa (/ OBJ1 OBJ2 name)
  (if
    (and (setq OBJ1 (_join1 "\n请拾取第一根线(LINE)或弧(ARC) <退出>:"))
         (setq
           OBJ2        (_join1
                  "\n再拾取第二根线(LINE)或弧(ARC)进行连接 <退出>: "
     (progn (_@ld "wltool2") (ucson) (wmend2 OBJ1 OBJ2) (ucsoff))
  (princ)
(defun C:tx (/ wd ss e na h)
  (prompt "\n请指定加粗的线段:")
  (if (setq ss (ssget (list (cons 0 "LINE,ARC,CIRCLE,*POLYLINE"))))
    (progn
      (setq wd (getdist "线段宽<50>:")
            wd (if wd
                 wd
                 50
      (ucson)
      (getss ss 0)
      (while (setq e (namess 0))
        (setq na (socas 0))
        (if (TgWcMatch na "*POLYLINE")
          (command ".PEDIT" e "_W" wd "")
          (progn
            (setq h (socas 39))
            (if        (= na "CIRCLE")
              (command ".BREAK"
                       e
                       (polar (socas 10) 0 (socas 40))
                       (polar (socas 10) 1e-3 (socas 40))
            (command ".PEDIT" e "Y" "_W" wd "")
            (if
              (and h
                   (= "LWPOLYLINE" (cdr (assoc 0 (entget (entlast)))))
               (command ".chprop" (entlast) "" "t" h "")
      (ucsoff)
(defun c:ts (/ mm p p0 p1 ss e na tf)
  (setq mm 0.1)
  (setvar "aperture" (getvar "pickbox"))
  (ucson)
  (while (and (setq p0 (entsel "\n请点取要打断的交点 <退出>: "))
              (setq p0 (osnap (last p0) "int"))
              (setq ss (pickss p0 mm 1))
    (while (setq e (namess 1))
      (cond ((= "LINE" (setq na (socas 0))) (setq tf T))
            ((= "ARC" na) (setq tf T))
            ((not (TgWcMatch na "*POLYLINE")) (setq tf nil))
            ((equal (nextent) p0 mm) (setq tf nil))
            ((progn (while (setq p (nextent)) (setq p1 p))
                    (equal p1 p0 mm)
             (setq tf nil)
            ((setq tf T))
      (if tf
        (command ".break" (list e p0) p0)
  (ucsoff)
(defun dsect (p1 p6 la / d sc p2 p3 p4 p5)
  (setq        la (cond ((and la (TgWcMatch la (glayer "临时*"))) "临时其它")
                 ((and la (TgWcMatch la (glayer "剖面*"))) "剖面其它")
                 ('T "其它")
        d  (* 0.5 (distance p1 p6))
        a  (angle p1 p6)
        sc (schdim "NORMAL")
        sc (min sc (/ d 150.))
        p2 (polar p1 a (- d (* sc 130)))
        p5 (polar p6 a (- (* sc 130) d))
        p3 (polar (polar p2 a (* sc 70)) (+ a _pi2) (* sc 220))
        p4 (polar (polar p5 a (* sc -70)) (+ a _pi2) (* sc -220))
        p1 (polar p1 a (* sc -280))
        p6 (polar p6 a (* sc 280))
  (begin la)
  (command ".line" p1 p2 p3 p4 p5 p6 "")
  (end)
(defun c:dsect2        (/ e p1 p2 la ss)
  (if (setq e (gete "\n选取剖断线的基线<起末点>: " '((0 . "LINE"))))
    (progn (getent)
           (setq p1 (socas 10)
                 p2 (socas 11)
                 la (socas 8)
           (entdel (car e))
    (if        (and (setq p1 (getspt "\n点取剖断线的起点<退出>: "))
             (setq p2 (getspt p1 "\n点取剖断线的终点<退出>: "))
      (if (or (setq ss (pickss p1 "剖面*,临时*" 1))
              (setq ss (pickss p2 "剖面*,临时*" 1))
        (progn (namess 1) (setq la (socas 8)))
        (setq la "其它")
  (if (and p1 p2)
    (dsect p1 p2 la)
  (princ)
这是从天正里拷出来的,是不是加密了?
已领礼包: 12496个
发表于 2008-5-19 19:02:20 | 显示全部楼层
程序中几乎关键部分全都使用了自定义的函数。
GMT+8, 2026-11-7 08:51 , Processed in 0.419934 second(s), 34 queries , Gzip On.
