查看: 927|回复: 2
[求助] [求助]:subst 不替换,哪位高手帮看下
发表于 2008-6-26 15:21:46 | 显示全部楼层 |阅读模式
请高手指点下
想修改块的插入点z坐标
(setq enlist (entget ename))
(setq pold (assoc 10 enlist))
(setq pnew (reverse (append zz (cdr (reverse pold)))));zz为z坐标,也用L
(setq enlist (subst penw pold enlist))
(entmod enlist)
变量情况:
pold:(10 -1830.17 1230.58 -3000.0)
pnew:(10 -1830.17 1230.58 500.0)
问题:subst后返回nil如下:
enlist返回值:
((-1 . <图元名: 7ef06690>) (0 . "INSERT") (330 . <图元名: 7ef05cf8>) (5 . "1AA") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "00-DQ") (62 . 3) (6 . "ByBlock") (100 . "AcDbBlockReference") (66 . 1) (2 . "M_Y5DGR") nil[/COLOR]  (41 . 350.0) (42 . 350.0) (43 . -350.0) (50 . 1.5708) (70 . 0) (71 . 0) (44 . 0.0) (45 . 0.0) (210 0.0 0.0 -1.0))
发表于 2008-6-26 21:34:48 | 显示全部楼层
检查一下变量名,呵呵,"pnew" "penw"
 楼主| 发表于 2008-6-26 22:26:35 | 显示全部楼层
晕,谢了。超不好意思
GMT+8, 2026-11-7 08:10 , Processed in 0.387212 second(s), 35 queries , Gzip On.
