查看: 931|回复: 1
[LISP函数]:帮忙修改一下算面积程序
发表于 2008-8-30 09:28:07 | 显示全部楼层 |阅读模式
面积标准
(DEFUN C:EA(/ OLDOS PT STA QAREA)
  (setq olderr *error*)
  (setq *error* myerr)
  (SETVAR "CMDECHO" 0)
  (SETQ OLDOS (GETVAR "OSMODE"))
  (SETVAR "OSMODE" 0)
  (SETQ STA (CAR (ENTSEL)))
  (COMMAND "AREA" "E" STA)
  (SETQ QAREA (RTOS (GETVAR "AREA") 2 2))
  (SETQ PT (GETPOINT"\nPick the point you want to write area:"))
  (COMMAND "TEXT" PT "" "" QAREA)
  (SETVAR "OSMODE" OLDOS)
  (SETVAR "CMDECHO" 1)
  (setq *error* olderr)
  (PRINC)
面积是精确到毫米平方,可以修改到米平方,小数点后二位?[/COLOR]
发表于 2008-8-31 00:53:00 | 显示全部楼层
(SETQ QAREA (RTOS (* 0.000001 (GETVAR "AREA") ) 2 2))
GMT+8, 2026-11-7 07:27 , Processed in 0.410229 second(s), 34 queries , Gzip On.
