查看: 1104|回复: 2
[LISP函数]:这个程序怎么用啊?
发表于 2008-9-1 21:06:12 | 显示全部楼层 |阅读模式
命令叫地形图切割,是做什么用的?
(defun c:scr (/             big   cmd count  dir          fname         name        pt1    pt3
              pt1-2  pt1-4  pt3-2  pt3-4  pt2         pt4        pt-list
              rot    ss            x1           y1          x3         y3        x0     y0
  (setq        rot (getvar "viewtwist")
        dir (getvar "dwgprefix")
        cmd (getvar "cmdecho")
  (setvar "cmdecho" 0)
  (while (or (= (setq name (getstring "请输入图名:")) "")
             (findfile (strcat name ".dwg"))
  (setq fname (strcat dir name))
  (if (not
        (setq pt1 (getpoint (getvar "extmin") "请选择左下角点:"))
    (setq pt1 (getvar "extmin"))
  (if (not (setq pt3 (getcorner pt1 "请选右上择角点:")))
    (setq pt3 (getvar "extmax"))
  (setq        x1 (car pt1)
        y1 (cadr pt1)
  (setq        x3 (car pt3)
        y3 (cadr pt3)
  (if (> x1 x3)
    (setq x0 x1
          x1 x3
          x3 x0
  (if (> y1 y3)
    (setq y0 y1
          y1 y3
          y3 y0
;;;根据选取的两对角点,考虑扭曲角度,计算另外两角点的坐标
  (setq pt1-2 (polar pt1 (- (* 2.0 pi) rot) 5000))
  (setq pt1-4 (polar pt1 (- (* 0.5 pi) rot) 5000))
  (setq pt3-2 (polar pt3 (- (* 1.5 pi) rot) 5000))
  (setq pt3-4 (polar pt3 (- (* 1.0 pi) rot) 5000))
  (setq pt2 (inters pt1 pt1-2 pt3 pt3-2 nil))
  (setq pt4 (inters pt1 pt1-4 pt3 pt3-4 nil))
  (setq big 0.01)
  (command "pline" pt1 pt2 pt3 pt4 "c")
  (setq ss (entlast))
  (command "zoom" pt1 pt3)
  (command "zoom" "0.95x")
  (setq count 6)
  (repeat 6
    (setq big (* big count))
    (setq pt5 (polar pt1 (- (dms 225) rot) big))
    (setq pt6 (polar pt2 (- (dms 315) rot) big))
    (setq pt7 (polar pt3 (- (dms 45) rot) big))
    (setq pt8 (polar pt4 (- (dms 135) rot) big))
    (setq count (- count 1))
    (command "trim" ss "" "f" pt5 pt6 pt7 pt8 pt5 "" "")
;;;end repeat
  (setq pt-list (list pt1 pt2 pt3 pt4))
  (setq ss (ssget "cp" pt-list))
  (command "wblock" fname "" (list 0 0) ss "")
  (setvar "cmdecho" cmd)
  (princ)
(defun dms (temp / rad)
  (setq rad (/ (* temp pi) 180))
命令叫地形图切割,是做什么用的?[/COLOR]
发表于 2008-9-1 22:14:01 | 显示全部楼层
程序加载后,输入scr调用。
 楼主| 发表于 2008-9-3 12:26:30 | 显示全部楼层
最初由 qjcpj 发布
[B]程序加载后,输入scr调用。 [/B]
我想问这个命令是做什么用的??在建筑里
GMT+8, 2026-11-5 14:42 , Processed in 0.425658 second(s), 36 queries , Gzip On.
