查看: 1427|回复: 1
[分享]:【CAD数字文本计算】:数字相乘,并标注
发表于 2008-9-3 18:26:24 | 显示全部楼层 |阅读模式
(DEFUN C:chen1()
(setq jd (getint "input 精度<0>:"))
(if (= jd nil) (setq jd 0))
(princ "\nselect object:")
(setq s (ssget))
(setq n (sslength s))
(setq k 0 )(setq mm 0.0)
(while (< k n)
      (setq name (ssname s k))
      (setq a (entget name))
      (setq t (assoc '0 a))
      (setq t (cdr t))
      (if (= t "TEXT") (PROGN
          (setq tx (assoc '1 a))
          (setq tx (cdr tx))
          (setq tx (atof tx))
          (if (= k 0) (setq MM TX))
          (if (/= k 0) (setq mm (* mm tx)))
      (setq k (+ k 1))
(setq mm (rtos mm 2 jd))
(setq po (getpoint "input point----:"))
(command "text" po ""  "" mm)
发表于 2008-9-10 19:53:21 | 显示全部楼层
见演示
GMT+8, 2026-11-22 08:29 , Processed in 0.247820 second(s), 12 queries , Gzip On, File On.
