查看: 2087|回复: 5
[编程申请]:如何快速合并多条线段
发表于 2008-9-11 10:18:36 | 显示全部楼层 |阅读模式
用mpedit命令每次都要选 yes,  join ,0 ,exit好几个选项,有没有办法把这几项合并成一个命令,或者有其他合并直线的命令也行,谢谢
发表于 2008-9-14 08:44:37 | 显示全部楼层
(defun c:tt ()
(command ".PEDIT" "M" pause "y" "j" 0 "")
(princ)
发表于 2008-9-16 13:00:30 | 显示全部楼层
我是cad初学者,这个怎么加载变为一个按钮,这样就可以方便使用
发表于 2008-9-27 20:16:00 | 显示全部楼层
把2楼的命令数值直接加入acad.lsp
里就可以用了,或另存一个文件,在cad里加载就能用了.
发表于 2008-10-2 16:02:03 | 显示全部楼层
呵呵
发表于 2008-10-29 18:48:13 | 显示全部楼层
下列程序可把LINE、ARC或LWPOLYLINE连在一起:
(defun c:jj(/ ss s)
     (setq ss (ssget '((-4 . "<OR")
                      (0 . "LINE")(0 . "ARC")
                      (-4 . "<AND")(0 . "LWPOLYLINE")(70 . 0)(-4 . "AND>")
                   (-4 . "OR>")))
  (while ss
    (setq s (ssname ss 0))
    (if (or (= "LINE" (cdr (assoc 0 (entget s))))
            (= "ARC" (cdr (assoc 0 (entget s))))
      (command "pedit" s "y" "j" "p" "" "x")
      (command "pedit" s "j" "p" "" "x")
    (setq ss (ssget "p"))
  (princ))
GMT+8, 2026-11-22 09:03 , Processed in 0.332528 second(s), 20 queries , Gzip On, File On.
