查看: 1281|回复: 1
[LISP程序]:坐标标注程序,应朋友要求写的,请大家指正
发表于 2009-1-4 08:34:29 | 显示全部楼层 |阅读模式
(defun c:IdDim(/ pt0x pt0y pt00 nnn pt1 pt1x pt1y pt2 lDist)
  (defun LispStart()
    (setq LUPREC (getvar "LUPREC"))
    (setvar "LUPREC" 3)
  (defun LispEnd()
    (setvar "LUPREC" LUPREC)
  (if (null pt0)
    (setq pt0  '(0 0))
  (setq pt0x (car pt0) pt0y (cadr pt0))
  (setq pt00 (getpoint (strcat "基准点<" (rtos pt0x) "," (rtos pt0y) ">:")))
  (if (null pt00)
    (setq pt00  pt0)
    (setq pt0  pt00)
  (if (null nn)
    (setq nn 1)
  (setq nnn (getint (strcat "基准序号<" (itoa nn) ">:")))
  (if (null nnn)
    (setq nnn nn)
    (setq nn nnn)
  (setq th (getreal (strcat "文字高度<" (rtos (getvar "textsize")) ">:")))
  (if (null th)
    (setq th (getvar "textsize"))
  (if (null lDist0)
    (setq lDist0 0)
  (setq lDist (getreal (strcat "文字行间距<" (rtos lDist0) ">:")))
  (if (null lDist)
    (setq lDist lDist0)
    (setq lDist0 lDist)
  (LispStart)
  (setq pt1 (getpoint pt0 (strcat "标注点 " (itoa nn) ":")))
  (while pt1
    (setq pt3 (getpoint pt1 "序号位置:"))
    (if (or (null pt2) (= ldist 0))
      (setq pt2 (getpoint pt1 "文字位置:"))
      (setq pt2 (list (car pt2) (- (cadr pt2) ldist)))
    (setq pt1x (car pt1) pt1y (cadr pt1))
    (command "_circle" pt1 (* 0.2 (getvar "dimtxt")))
    (command "_text" "j" "mc" pt3 th "" (itoa nn))
    (command "_text" pt2 th "" (strcat "[" (itoa nn) "] x=" (rtos (- pt1x pt0x)) ", y=" (rtos (- pt1y pt0y))))
    (setq nn (1+ nn))
  (LispEnd)
  (princ)
发表于 2009-1-8 16:12:22 | 显示全部楼层
多谢!
GMT+8, 2026-11-22 10:50 , Processed in 0.513835 second(s), 12 queries , Gzip On, File On.
