查看: 1172|回复: 0
[讨论]:带提示和过滤表的entsel
发表于 2009-3-7 19:01:11 | 显示全部楼层 |阅读模式
功能: 1.带提示和过滤表的entsel;
        2.循环直到选中有效实体或选择退出为止;
       论坛以前也有相关贴子,方法略有不同,借鉴前辈的一些思路,尽供参考.
(defun c:fssel (/ filter_check na)
  (setq msg "\nSelect touching object: ")
  (setq flt '((0 . "TEXT") (8 . "beam")
         (40 . 600.0)(62 . 4)
  ) ;local function
  (defun filter_check (na flt / e1 a n flag)
    (cond
      ((not na)
        (setq flag nil)
      ((not flt)
        (setq flag T)
      (T
        (setq e1 (entget na));setq
        (setq n 0)
        ;(setq flag t)
        (while (and
                  (not flag)
                 (< n (length flt))
               );and
          (setq a (nth n flt));setq
          ;setq then got a match for the filter
          (if (not (member a e1))(setq n (length flt)))
         (if (and (member a e1)(= n (-(length flt )1)))(setq flag t)) ;if
          (setq n (+ n 1));setq
        );while
    );cond close
    flag
  );defun filter_check
  (if (not (equal (substr msg 1 1) "\n"))
    (setq msg (strcat "\n" msg))
  );if
  (while (not na)
    (setvar "errno" 0)
    (while (or
             (and
               (not (setq na (car (entsel msg))))
               (equal 7 (getvar "errno"))
             );and
             (and
               na
               (not (filter_check na flt))
             );and
           );or
      (if (equal 7 (getvar "errno"))
        (princ "\n0 found")
        (progn
          (if na
            (princ (strcat "\n*Invalid select*  "
                   );strcat
            );princ
          );if
        );progn
      );if
      (setvar "errno" 0)
    );while
    (cond
      ((equal (getvar "errno") 52) ;enter
        (setq na 99);
    );cond close
  );while
  (if (equal na 99)
    (setq na nil)
  na
GMT+8, 2026-11-4 22:31 , Processed in 0.373439 second(s), 31 queries , Gzip On.
