查看: 1252|回复: 1
[求助] [求助]:帮我解决一下,用vlisp不能插入块的问题
发表于 2009-5-23 16:36:22 | 显示全部楼层 |阅读模式
我在autocad支持的搜索路径下面放了个名叫"111.dwg"的图形
(defun RRR ()
(vl-load-com)
(setq acadobject (vlax-get-acad-object))
(setq acaddocument (vla-get-activedocument acadobject))
(setq mspace (vla-get-modelspace acaddocument))
(vla-insertblock mspace (vlax-3d-point (list 0 0 0)) "111" 1 1 1 0)
用以上的程序插不进来,而用(command "insert" "111" (list 0.0 0.0 0.0) "1" "1" "")却能进来,请大师们帮我指点一下.
发表于 2009-5-24 09:32:46 | 显示全部楼层
试试:
  1. (vl-load-com)
  2. (setq acadobject (vlax-get-acad-object))
  3. (setq acaddocument (vla-get-activedocument acadobject))
  4. (setq mspace (vla-get-modelspace acaddocument))
  5. (vla-insertblock mspace (vlax-3d-point (list 0 0 0)) (findfile "111.dwg") 1 1 1 0)
GMT+8, 2026-11-2 21:50 , Processed in 0.478511 second(s), 34 queries , Gzip On.
