查看: 2787|回复: 5
[求助] [求助]:LISP程序,是循环错了还是变量问题
发表于 2009-9-21 18:00:54 | 显示全部楼层 |阅读模式
(defun c:bili ()
   (setvar "cmdecho" 0)
   (setq re 1)
   (while (= re 1)
    (princ "\n本程序用于钻孔分层<For 2004>")
    (SETQ jq (GETreal "\n请输入钻孔分层深度:"))
    (setq jq2 (GETdist"\n请输入钻孔最后一层深度:"))
    (if (= jq2 nil)(print"未输入最大孔深"))
    (if (/= jq nil)
    (progn
    (if (<= jq2 43);小于等43米比例尺为1:200
    (progn
     (command "text" "37.667,242.086,0" "2.5" "0d" "1:200" "" )
     (setq ks1 (* jq 5))
         (if (> jq2 43);大于43米比例尺为1:500
        (progn
          (command "text" "37.667,242.086,0" "2.5" "0d" "1:500" "")
          (setq ks1 (* jq 2))
    (setq pa1 (polar '(0 238) 4.712389 ks1))
    (setq pa2 (polar '(36 238) (* pi 1.5) ks1))
    (setq pa3 (polar '(46 238) (* pi 1.5) ks1))
    (command "pline" pa1 pa2 "")
    (command "pline" pa2 pa3 "")
  (princ "\n没有输入分层深度!")
  (setq Re (getvar "useri1"))
  (prompt "*************** << C:bili >> *****************")
  (prin1)
改了一下程序,现在可以用了,只是出现提示,说命令未定义。可有高人帮指出问题?
发表于 2009-9-21 18:47:06 | 显示全部楼层
看不懂,高人啊
发表于 2009-9-22 01:54:51 | 显示全部楼层
我需要这个,谢谢
我需要这个,谢谢
发表于 2009-9-22 08:39:17 | 显示全部楼层
(command "text" "37.667,242.086,0" "2.5" "0d" "1:500")
发表于 2009-9-22 11:13:02 | 显示全部楼层
将(command "text" "37.667,242.086,0" "2.5" "0d" "1:200" "" )和(command "text" "37.667,242.086,0" "2.5" "0d" "1:500" "") 最后的 "" 去掉。
  1.   [FONT=courier new]
  2. (defun c:bili ()
  3.   (setvar "cmdecho" 0)
  4.   (princ "\n本程序用于钻孔分层")
  5.   (while (SETQ jq (GETreal "\n请输入钻孔分层深度:"))
  6.     (setq jq2 (GETdist"\n请输入钻孔最后一层深度:"))
  7.     (if jq2
  8.       (progn
  9.         (if (<= jq2 43);小于等43米比例尺为1:200
  10.           (progn
  11.            (command "text" "37.667,242.086,0" "2.5" "0d" "1:200")
  12.            (setq ks1 (* jq 5))
  13.           )
  14.         )
  15.         (if (> jq2 43);大于43米比例尺为1:500
  16.           (progn
  17.             (command "text" "37.667,242.086,0" "2.5" "0d" "1:500")
  18.             (setq ks1 (* jq 2))
  19.           )
  20.         )
  21.         (setq pa1 (polar '(0 238) 4.712389 ks1))
  22.         (setq pa2 (polar '(36 238) (* pi 1.5) ks1))
  23.         (setq pa3 (polar '(46 238) (* pi 1.5) ks1))
  24.         (command "pline" pa1 pa2 "")
  25.         (command "pline" pa2 pa3 "")
  26.       )
  27.     )
  28.     (setq Re (getvar "userr1"))
  29.   )
  30.   (prompt "*************** << C:bili >> *****************")
  31.   (prin1)
  32. )
  33.   [/FONT]
 楼主| 发表于 2009-9-23 18:37:31 | 显示全部楼层
谢谢,果然如楼上所说,去掉""就可以了。
GMT+8, 2026-11-22 07:49 , Processed in 0.281617 second(s), 20 queries , Gzip On, File On.
