查看: 15200|回复: 38
[原创]:批量生成复合线边界的LISP程序
发表于 2010-2-2 18:57:11 | 显示全部楼层 |阅读模式
[C] 纯文本查看 复制代码
;;; La为图层名(defun Layer_zdsb (La / sel make_point_list n mn en entype pt1 pt2 pL sel k
		      p1 p2 enlast ensel
				       ; 表操作函数
				       ; 判断点 p1 是否在点集PL中,是返回T
				       ; ,不是返回nil,a为精度
				       ; 例 (IsInPointList '(1.0001 1.001 0)
				       ; '((1 1 0) (2 1 0)) 0.001),返回T
  (defun IsInPointList (p1 PL a)       ; (setq n (length PL))
    (if (member t (mapcar
		    '(lambda (b)
		       (equal p1 b a)
		    PL
      t
      nil
  )				       ; 取出图元索引i对应的值
  (defun dxf (ent i)
    (cdr (assoc i (entget ent)))
  )				       ; 取圆弧的起点、终点。中点
  (defun arc_3point (a / cenp radius STP ENPmp arcmidpoint)
    (setq cenp (cdr (assoc 10 (entget a))))
    (setq radius (cdr (assoc 40 (entget a))))
    (setq STP (vlax-curve-getPointAtParam A
					  (vlax-curve-getstartparam A)
    (setq ENP (vlax-curve-getPointAtParam A (vlax-curve-getEndParam A)))
    (setq arcmidpoint (polar (polar stp (angle stp enp) (/
							   (distance STP ENP)
							   2.0
			     ) (angle cenp (polar stp (angle stp enp)
						  (/ (distance STP ENP) 2.0)
			       ) (- radius (distance (polar stp
							    (angle stp enp)
							       (distance STP ENP)
							       2.0
						     ) cenp
    (list stp enp arcmidpoint)
  ;; 根据选择集中的line、arc、circle,生成点集
  (defun make_point_list (s / PL)
    (setq n 0
	  PL '()
	  mn (sslength s)
    (repeat mn
      (setq en (ssname s n)
	    enType (dxf en 0)
      (cond
	((= enType "LINE")
	  (setq pt1 (dxf en 10)
		pt2 (dxf en 11)
	  (if (not (IsInPointList pt1 pl 0.00001))
	    (setq pl (cons pt1 pl))
	  )			       ; if
	  (if (not (IsInPointList pt2 pl 0.00001))
	    (setq pl (cons pt2 pl))
	  )			       ; if
	((= enType "ARC")
	  (setq pt1 (car (arc_3point en))
		pt2 (cadr (arc_3point en))
	  )			       ; if
	  )			       ; if
      )				       ; cond
      (setq n (1+ n))
    )				       ; repeat
    (setq pl pl)
  )				       ; make_point_list
				       ; 此处SEL选择集可自行修改为命令行选择
				       ; 代码
  (setq sel (ssget "x" (list '(0 . "line,arc,circle") (cons 8 La))))
  (if sel
    (progn
      (setq Plist (make_point_list sel))
      (setq enlast (entlast)
	    ensel (ssadd)
      (setvar "CLAYER" la)
      (command "_.boundary" "a" "b" "n" sel "" "")
      (setq n -1
	    mn 0
	    k (length Plist)
      (repeat k
	(setq p0 (nth (setq n (1+ n))
		      Plist
	      mn n
	(repeat (- k n 1)
	  (setq p1 (nth (setq mn (1+ mn))
			Plist
	  (setq p2 (midpoint p0 p1))
	  (command p2)
	)			       ; repeat
      )				       ; repeat
      (command "")
      (while (setq en (entnext enlast))
	(setq enlast en)
	(ssadd en ensel)
      )				       ; while
      (command "erase" sel "")
      (setq ensel ensel)
    )				       ; progn
    nil
  )				       ; if
本帖被以下淘专辑推荐:
发表于 2010-2-11 14:55:18 | 显示全部楼层
执行的命令是多少?
发表于 2010-2-11 16:20:47 | 显示全部楼层
类似——暗柱边线
发表于 2010-2-11 17:30:14 | 显示全部楼层
xyp1964斑竹 ,你的程序非常好
发表于 2010-3-9 11:32:46 | 显示全部楼层
好东东,怎么导入CAD呢?
 楼主| 发表于 2010-3-18 19:39:14 | 显示全部楼层
为了提高生成Boundary边界的效率,可对选择集的直线、园作一下打断处理,具体打断方法本论坛有很多讨论。可参见下帖:
http://www.xdcad.net/forum/showt ... splay=&pagenumber=2
;然后将下述述代码做如下改动:
;;;此处SEL选择集可自行修改为命令行选择代码
(if sel
(progn
(setq enlast (entlast) ensel (ssadd))
(command "_.boundary" "a" "b" "n" sel "" "" )
(setq n -1
mn 0
k (length Plist))
(repeat k
(setq p0 (nth (setq n (1+ n)) Plist) mn n)
(repeat (- k n 1)
(setq p1 (nth (setq mn (1+ mn)) Plist))
(command p2)
);repeat
);repeat
(command "")
[QUOTE]
代码改动如下:
;;;插入打断代码
(princ (strcat "\n正在整理 " La " 数据..........."))
  ;此处自行添加打断代码
(if sel
  (progn
   (zoom_window (setq recList (get_rec_pointlist Plist)))
   ;;;计算点范围Y值的五百分之一
   (setq VerticalLimit (* 0.002 (- (cadadr recList) (cadar recList))))
   (if (< VerticalLimit 0.2) (setq VerticalLimit 0.2))
   ;;;如果enlast为块定义,得到最后子图元
   (while (entnext enlast)
     (setq enlast (entnext enlast))
   (setq enlast1 enlast)
  (command "_.boundary"  "a" "i" "n" "+x" "b" "n" sel "" "" )
(setq ki -1
        k (sslength Sel))
   (princ "\n共有 ")
   (princ K)
   (princ " 边,正在生成边界.........")
   (princ K)
  (repeat k
    (setq en-line (ssname Sel (setq ki (1+ ki)))
         LpLst (LAC-LR-Point en-line VerticalLimit);直线两边点
    (command (car LpLst))
    (command (cdr LpLst))
    );repeat
  (command "")
这样生成边界的速度可比原程序快十倍,选择物体越多,速度差距越明显!
发表于 2010-3-20 20:48:32 | 显示全部楼层
命令是什么呢   没看出用什么唤起啊
 楼主| 发表于 2010-3-23 22:48:37 | 显示全部楼层
我把完整的程序源码传上来,请大家使用,源码见附件!加载boundary.lsp后,command命令下敲入 bianjie即可运行!
发表于 2013-4-2 10:29:15 | 显示全部楼层
没看到附件啊
强烈支持,G版主就是牛啊
发表于 2013-4-2 10:35:11 | 显示全部楼层
:lol顶下G版的帖子,算法高明
发表于 2013-4-2 15:35:55 | 显示全部楼层
Gu_xl:lol在这也有啊
发表于 2013-4-6 16:10:50 | 显示全部楼层
支持!!!:lol:lol:lol
发表于 2013-4-12 14:09:01 | 显示全部楼层
我也来支持;P;P
发表于 2013-4-18 17:23:11 | 显示全部楼层
好贴!G版主厉害!!!
发表于 2013-4-18 17:27:48 | 显示全部楼层
期待G版主的完整代码
GMT+8, 2026-11-22 07:36 , Processed in 0.408846 second(s), 38 queries , Gzip On, File On.
