查看: 2144|回复: 0
[分享] Creating block from selection set
发表于 2013-5-25 02:54:21 | 显示全部楼层 |阅读模式
Creating block from selection setBy Virupaksha Aithal
Below code shows the procedure to create a new block table record from entities selected on screen.  The important function used is “DeepCloneObjects” which takes collections of object ids to be copy. The second parameter is the “owner” of the copied entities. In the below code, the block table record (“test”) is passed as owner, so that the selected entities clone objects are copied to block table record
  1. [CommandMethod("CreateBlock")]
  2. public void CreateBlock()
  3. {
  4.     Document doc = Application.DocumentManager.MdiActiveDocument;
  5.     Database db = doc.Database;
  6.     Editor ed = doc.Editor;
  7.     TypedValue[] filterlist = new TypedValue[1];
  8.     filterlist[0] = new TypedValue(0, "CIRCLE,LINE");
  9.     SelectionFilter filter = new SelectionFilter(filterlist);
  10.     PromptSelectionOptions opts = new PromptSelectionOptions();
  11.     opts.MessageForAdding = "Select entities: ";
  12.     PromptSelectionResult selRes = ed.GetSelection(opts, filter);
  13.     if (selRes.Status != PromptStatus.OK)
  14.     {
  15.         return;
  16.     }
  17.     ObjectId[] ids = selRes.Value.GetObjectIds();
  18.     ObjectId blockId = ObjectId.Null;
  19.     //add a block table record with name test...
  20.     using (Transaction Tx = db.TransactionManager.StartTransaction())
  21.     {
  22.         BlockTable bt = (BlockTable)Tx.GetObject(db.BlockTableId,
  23.                                                    OpenMode.ForRead);
  24.         if (!bt.Has("Test"))
  25.         {
  26.             bt.UpgradeOpen();
  27.             //create new
  28.             BlockTableRecord record = new BlockTableRecord();
  29.             record.Name = "Test";
  30.             bt.Add(record);
  31.             Tx.AddNewlyCreatedDBObject(record, true);
  32.         }
  33.         blockId = bt["Test"];
  34.         Tx.Commit();
  35.     }
  36.     //copy the select entities to block by using deepclone.
  37.     ObjectIdCollection collection = new ObjectIdCollection(ids);
  38.     IdMapping mapping = new IdMapping();
  39.     db.DeepCloneObjects(collection, blockId, mapping, false);
  40. }
评分
参与人数 1D豆 +2 收起 理由
ScmTools + 2 很给力!资料分享奖!
查看全部评分
GMT+8, 2026-11-22 07:50 , Processed in 0.554715 second(s), 10 queries , Gzip On, File On.
