查看: 4087|回复: 16
[LISP程序]:毋须EXplode,编辑属性块中属性的小工具
发表于 2003-7-3 08:43:49 | 显示全部楼层 |阅读模式
毋须EXplode,编辑属性块中属性的小工具. 此代码只是实现基本功能, 请大家试用!
(defun c:test ()
  (vl-load-com)
  (setq att (getstring "\nChange attribute [Angle/Color/Height/Layer/Position/Style/Value/Tagstring]: "))
  (setq obj (car (nentsel "\nSelect an Attribute: ")))
  (setq obj (vlax-ename->vla-object obj))
  (cond
    ((= (strcase att) "A")
      (setq ang (getstring t "\nNew Angle: "))
      (vlax-put-property obj 'rotation ang))
    ((= (strcase att) "C")
      (setq col (getstring "\nNew Color Number: "))
      (vlax-put-property obj 'color col))
    ((= (strcase att) "H")
      (setq ohei (vlax-get-property obj 'height))
      (setq hei (getdist (strcat "\nNew Height <" (rtos oh 2 2) ">:")))
      (if (= hei "")(setq hei ohei))
      (vlax-put-property obj 'height hei))
    ((= (strcase att) "L")
      (setq lay (getstring "\nNew Layer:"))
      (if (not (tblsearch "LAYER" lay))
        (alert (strcat "\nLayer " (strcase lay) " doesn't exist!"))
        (vlax-put-property obj 'layer lay)
    ((= (strcase att) "P")
      (setq pos (getpoint "\nNew Position:"))
      (vlax-put-property obj 'textalignmentpoint (vlax-3d-point pos)))
    ((= (strcase att) "S")
      (setq sty (getstring "\nNew Style: "))
      (if (not (tblsearch "STYLE" sty))
        (alert (strcat "\nThe style " (strcase sty) " doesn't exist!"))
        (vlax-put-property obj 'stylename sty)
    ((= (strcase att) "V")
      (setq val (getstring t "\nNew value: "))
      (vlax-put-property obj 'textstring val))
  );c
  (princ)
);defun
发表于 2003-7-30 10:19:58 | 显示全部楼层
谢谢了,还可以用。
发表于 2004-12-12 16:51:17 | 显示全部楼层
用探索者中的“通用编辑”更好些!
发表于 2004-12-12 22:32:41 | 显示全部楼层
希望能加上对话框。
发表于 2004-12-13 12:14:40 | 显示全部楼层
谢谢楼主,很好用!
发表于 2004-12-16 15:42:14 | 显示全部楼层
4楼说得对,有对话框就好了,希望能加上对话框。
发表于 2006-8-19 11:51:05 | 显示全部楼层
我碰到一个块BURST命令炸不开,正不知道怎么会事呢,见附件!
发表于 2007-12-5 21:47:36 | 显示全部楼层
什么 东东啊
发表于 2007-12-11 19:41:07 | 显示全部楼层
应补充对话框好点,同时,应提示旧属性是何值,以利于修改时对照
发表于 2007-12-12 13:21:48 | 显示全部楼层
不知道有什么用
发表于 2007-12-13 22:02:45 | 显示全部楼层
谢谢```
发表于 2007-12-13 23:11:56 | 显示全部楼层
什么用 ?
发表于 2008-11-24 16:53:12 | 显示全部楼层
有些地方出错,希望楼主再调试一下
发表于 2008-11-29 16:22:30 | 显示全部楼层
学习下
发表于 2008-12-13 00:38:46 | 显示全部楼层
收下‘
GMT+8, 2026-11-22 09:47 , Processed in 0.373732 second(s), 38 queries , Gzip On, File On.
