查看: 2945|回复: 5
[求助] [求助]:vl-string-subst的使用?
发表于 2003-7-5 20:52:34 | 显示全部楼层 |阅读模式
(setq dat "WF2               496.96                 497.90         0.94");空档为空格和制表符的混合
(setq well (vl-princ-to-string (read dat)))
(setq dat (vl-string-subst " " well dat 0))
(setq p-al (vl-princ-to-string (read dat)))(setq p-al-real (atof p-al))
(setq dat (vl-string-subst " " p-al dat 0))
(setq g-al (vl-princ-to-string (read dat)))(setq g-al-real (atof g-al))
(setq dat (vl-string-subst " " g-al dat 0))
(setq cover (vl-princ-to-string (read dat)))
cover应为0.94,但实际运行却为0,即在(setq dat (vl-string-subst " " g-al dat 0))中0.94前生出错误的0
请高手指教,多谢!
发表于 2003-7-5 22:44:57 | 显示全部楼层
READ对小数点后末尾的0忽略不计,所以到497.90时返回的数据为497.9则只是替换掉了497.9所以剩下最后的0,这就是出现0的原因
 楼主| 发表于 2003-7-6 08:51:52 | 显示全部楼层
多谢斑竹,我已找到解决办法,用
(setq well(vl-princ-to-string (read dat)))
(setq dat (substr dat (+ 1 (strlen well) (vl-string-search well dat))))
(while (= (substr dat 1 1) "0")
(setq dat (substr dat 2))
发表于 2003-7-7 11:11:11 | 显示全部楼层
终于熬到放假了,高兴!
YYNT朋友,你的方法无法解决0被消掉的问题哦,为了保持数据的原样是不是可以这样哦:
  1. [font=courier new]
  2. (setq dat "WF2 496.96 497.90 0.94"
  3.        qing_aa (substr dat (+ 2 (vl-string-search " " dat)))
  4.        well (vl-string-right-trim qing_aa dat)
  5.        qing_aa1 (substr qing_aa (+ 2 (vl-string-search " " qing_aa)))
  6.        p-al (vl-string-right-trim qing_aa1 aa)
  7.        cover (substr qing_aa1 (+ 2 (vl-string-search " " qing_aa1)))
  8.        g-al (vl-string-right-trim cover qing_aa1)
  9.       )
  10. [/font]
已领礼包: 488个
发表于 2003-7-9 19:59:14 | 显示全部楼层
这问题问的多了.用read不是最好的办法.
要空格分开字符.
http://www.xdcad.net/forum/showthread.php?s=&threadid=66654
一劳永逸.
当然还能以任意字符来分.把空格换成字符就可.
发表于 2003-7-10 08:06:05 | 显示全部楼层
最初由 jianqiang21c 发布
[B]终于熬到放假了,高兴!
[code]
       qing_aa (substr dat (+ 2 ... [/B]
没想道还是一名未毕业的学生,就已经是版主了,看来我等是白活了。
GMT+8, 2026-11-3 19:09 , Processed in 0.698143 second(s), 42 queries , Gzip On.
