查看: 993|回复: 1
[求助] 这个问题哪位高手可以帮着解决一下,苦苦在线等待。。。
发表于 2016-8-20 15:13:31 | 显示全部楼层 |阅读模式
在win下启动EXCEL和在CAD中用(startapp "EXCEL"  启动EXCEL是不同的,好象启动了两个EXCEL系统,EXCEL的图标都不同,如何解决,请问高手们。。。
 楼主| 发表于 2016-8-20 15:27:55 | 显示全部楼层
多试过其它的方法
(defun excel-open
   (XLSFile UnHide / ExcelApp WorkSheet Sheets ActiveSheet Rtn)
   (setq XLSFile (strcase XLSFile))
   (if (null (wcmatch XLSFile "*.XLS" ))
      (setq XLSFile (strcat XLSFile ".XLS" ))
   (if (and (findfile XLSFile) (setq Rtn (vlax-get-or-create-object "Excel.Application" )))
      (progn
         (vlax-invoke-method
            (vlax-get-property Rtn 'WorkBooks)
            'Open
            XLSFile
         (if UnHide
            (vla-put-visible Rtn 1)
            (vla-put-visible Rtn 0)
   Rtn
(princ "\n已打开EXCEL!\n")
(princ)
(defun openexcelexist (xfile dmode / appsession)
  (cond
    ((setq excl (vlax-get-or-create-object "Excel.Application"))
      (vlax-invoke-method (vlax-get-property excl 'workbooks) 'open xfile)
      (if (= (strcase dmode) "SHOW")
        (vla-put-visible excl 1)
        (vla-put-visible excl 0)
  excl
(princ)
(defun openexcelnew (dmode / xlapp)
  (cond
    ((setq xlapp (vlax-create-object "Excel.Application"))
      (vlax-invoke-method (vlax-get-property xlapp 'WorkBooks) 'Add)
        (vla-put-visible xlapp 1)
        (vla-put-visible xlapp 0)
  xlapp
(princ)
程序启动EXCEL,EXCEL中自定义的工具栏就不显示了,也就是EXCEL启动的初始化未执行。。。
GMT+8, 2026-11-5 22:53 , Processed in 0.531656 second(s), 35 queries , Gzip On.
