查看: 10311|回复: 31
[多段线] 统计多段线顶点坐标并生成表格
发表于 2016-10-16 04:29:08 | 显示全部楼层 |阅读模式
  • 插件名称 : 坐标统计
  • 作  者 : Lispboy
  • 运行环境 :XDRX API 晓东工具箱
  • 发布时间 :2016-10-16
  • 命令名称 :XDTB_TJPolyVertex
  • 插件介绍 :统计多段线顶点坐标并生成表格
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
函数
1、XD::Pnt:isPits 见: http://bbs.xdcad.net/thread-705797-1-1.html
2、xd::dimleaderindex:make 见:http://bbs.xdcad.net/thread-705795-1-1.html
[sell=5]
(defun c:XDTB_TJPolyVertex (/ #height e elev i inxs lst num p- p+ p1 p2 pt
                              pts v v- v+ x
  (defun _drawindex (e)
    (setq num (xdrx_polyline_numverts e)
          i -1
    (repeat num
      (setq inxs (xd::polyline:-index+ e (setq i (1+ i))))
      (setq p1 (xdrx_getpropertyvalue e "pointat" i)
            p- (xdrx_getpropertyvalue e "pointat" (car inxs))
            p+ (xdrx_getpropertyvalue e "pointat" (cadr inxs))
            v- (mapcar
                 p-
                 p1
            v- (xdrx_vector_normalize v-)
            v+ (mapcar
                 p+
                 p1
            v+ (xdrx_vector_normalize v+)
            v (mapcar
                v-
                v+
            v (xdrx_vector_normalize v)
      (setq p1 (xd::pnt:setz p1 0.0))
      (if (not (xd::pnt:isPits e p1))
        (progn
          (setq v (xdrx_vector_negate v))
      (setq p2 (mapcar
                 p1
                 (xdrx_vector_product v #height)
      (xd::dimleaderindex:make (itoa (1+ i)) #height p1 p2 (/ #height 5.0)
                               "_none" 0
  (XD::Doc:CheckAcadVersion '>= "2008" "")
  (if (and
        (setq #height (getreal "\n输入字高<退出>:"))
        (setq e (car (xdrx_entsel "\n拾取多段线<退出>:" '((0 . "*POLYLINE")))))
    (progn
      (xdrx_begin)
      (xdrx_sysvar_push '("dimzin" 0))
      (if (= "POLYLINE" (car (xdrx_object_classname e)))
        (xdrx_polyline_convertfrom e)
      (xdrx_polyline_compress e t)
      (setq pts (xdrx_getpropertyvalue e "vertices")
            elev (xdrx_getpropertyvalue e "elevation")
      (if (xd::pnts:isclockwise pts)
        (progn
          (setq pts (reverse pts))
          (xdrx_curve_reverse e)
      (xd::text:init 1)
      (_drawindex e)
      (if (setq pt (getpoint "\n表格插入点<退出>:"))
        (progn
          (setq lst (list (list "多段线顶点坐标" " " " " " ") (list "编号"
        "X坐标"
        "Y坐标"
        "Z坐标"
          (setq i 0)
          (setq lst (append
                      lst
                      (mapcar
                        '(lambda (x)
                           (setq i (1+ i))
                           (list (itoa i) (rtos (cadr x) 2 4) (rtos
        (car x)
        2 4
                                 (rtos elev 2 1)
                        pts
          (xd::table:makefromlist lst pt #height (/ #height 2.0))
      (xdrx_sysvar_pop)
      (xdrx_end)
  (princ)
[/sell]
发表于 2016-10-17 11:08:48 | 显示全部楼层
回的人少,我来小顶一下
发表于 2016-10-17 14:47:47 | 显示全部楼层
学习一下,谢谢分享
发表于 2016-12-28 11:52:40 | 显示全部楼层
这个应该比较多人用吧
发表于 2017-1-19 16:10:49 | 显示全部楼层
啥也不说了,感谢楼主分享哇!
发表于 2017-4-27 18:51:18 | 显示全部楼层
不能用啊。怎么办
发表于 2017-4-28 12:57:43 | 显示全部楼层
谢谢楼主分享!
发表于 2017-8-27 14:05:44 | 显示全部楼层
运行提示参数错误,我下载的最新的函数库和工具箱
发表于 2017-9-11 13:42:28 | 显示全部楼层
在选取多段线后出现错误
错误: no function definition: xdrx_mleader_make
发表于 2017-9-11 14:57:45 | 显示全部楼层
装了2017年8月份的晓东工具箱后 还是不能用 提示lentityp <Selection set: 7e3>
发表于 2018-3-18 17:51:05 | 显示全部楼层
过来看看,什么好东西。
评分
参与人数 1D豆 +5 收起 理由
dyjwyqz5221 + 5
查看全部评分
发表于 2018-3-18 23:33:51 | 显示全部楼层
不错的工具。看看思路
发表于 2018-3-26 09:47:26 | 显示全部楼层
学习一下,谢谢分享
发表于 2018-3-30 19:03:54 | 显示全部楼层
不错这个东西
发表于 2018-3-30 22:11:22 | 显示全部楼层
谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享谢谢分享
GMT+8, 2026-11-22 10:35 , Processed in 0.458645 second(s), 39 queries , Gzip On, File On.
