查看: 30068|回复: 83
[图块] 修改图块的插入点
 火 [复制链接]
发表于 2019-3-14 21:20:27 | 显示全部楼层 |阅读模式
  • 插件名称 : 修改图块的插入点
  • 作  者 : odelywp
  • 运行环境 :不限
  • 发布时间 :2019-03-14
  • 命令名称 :basc
  • 插件介绍 :有些人做图块时不注意块的插入点,甚至插入点在图块外很远的地方. 本程序用于修改插入点到选定点处
  • 备  注 : (点击图片可以放大)
(点击图片可以放大)
2、在ACAD中如何加载插件,请看 论坛插件使用方法
3、如果您有要求需要定制插件,请到 编程申请 论坛发帖求助
插件详细内容
命令:BASC;源码回复可见(defun c:basc( / blk pt blk2 blk41 blk42 blk50 blk10 temposm lin sset bnum npt blkpro)
        (defun point(pbase sx sy) (list (+ (car pbase) sx)(+ (cadr pbase) sy)))        (defun ass (num entity / tempvalue)
        (setq tempvalue (cdr (assoc num (entget entity))))
        (if (and (= 62 num) (null tempvalue)) (setq tempvalue 256))
        (if (and (= 6 num) (null tempvalue)) (setq tempvalue "Bylayer"))
        (setq tempvalue tempvalue))
        (command "undo" "be")
        (setq blk(car (entsel "\n选择需调整插入点的块:")))
        (command "ucs" "")
        (setq pt (getpoint "\n新的插入点:"))
        (setq blkpro (entget blk))
        (setq blk2 (cdr (assoc 2 blkpro)))
        (setq blk41 (cdr (assoc 41 blkpro)))
        (setq blk42 (cdr (assoc 42 blkpro)))
        (setq blk50 (cdr (assoc 50 blkpro)))
        (setq blk10 (cdr (assoc 10 blkpro)))
        (setq temposm (getvar "osmode"))
        (setvar "osmode" 0)
        (command "line" blk10 pt "")
        (setq lin (entlast))
        (if (/= blk50 0.0) (command "rotate" lin "" blk10 (* -180.0 (/ blk50 pi))))
        (setq pt (list (/ (- (nth 0 (ass 11 lin)) (nth 0 blk10)) blk41) (/ (- (nth 1 (ass 11 lin)) (nth 1 blk10)) blk42)))
        (command "erase" lin "")
        (command "bedit" blk2)
        (command "move" "all" "" pt (list 0 0))
        (command "bclose" "")
        (setq sset (ssget "x" (list (cons 0 "INSERT")(cons 2 blk2))))
        (setq bnum 0)
        (while (setq blk (ssname sset bnum))
                (setq blk10 (ass 10 blk))
                (setq npt (point blk10 (* (ass 41 blk) (nth 0 pt)) (* (ass 42 blk) (nth 1 pt))))
                (command "line" blk10 npt "") (setq lin (entlast))
                (if (/= (setq blk50 (ass 50 blk)) 0.0) (command "rotate" lin "" blk10 (* 180.0 (/ blk50 pi))))
                (command "move" blk "" blk10 (ass 11 lin))
                (setq bnum (1+ bnum))
        (setvar "osmode" temposm)
        (command "undo" "e")
        (princ)
basc.zip
1.49 KB, 下载次数: 86, 下载积分: D豆 -1 , 活跃度 1
发表于 2019-3-14 21:53:07 | 显示全部楼层
纯LISP的,不错
发表于 2019-3-14 22:02:20 | 显示全部楼层
谢谢分享! 回覆学习!!!!!
发表于 2019-3-15 06:45:21 | 显示全部楼层
实用的工具,谢谢分享
发表于 2019-3-15 07:52:25 | 显示全部楼层
谢谢楼主分享
发表于 2019-3-15 08:02:43 | 显示全部楼层
谢谢分享6666
发表于 2019-3-15 09:57:14 | 显示全部楼层
不错的插件,谢谢楼主分享。
发表于 2019-3-15 10:48:38 | 显示全部楼层
实用的工具,谢谢分享
发表于 2019-3-15 11:22:39 | 显示全部楼层
感谢分享,,这个功能CAD是不是有自带的1?
发表于 2019-3-15 11:33:02 | 显示全部楼层
看看学学习以下
发表于 2019-3-15 11:38:51 | 显示全部楼层
直接编辑块也可以的。
那在图上的位置就不是原来的位置了  发表于 2019-3-15 11:46
 楼主| 发表于 2019-3-15 11:56:32 来自手机 | 显示全部楼层
tzfcn 发表于 2019-3-15 11:38
直接编辑块也可以的。
如果这个块有多个,直接修改后这些块就会改变他它们的位置,需要一个个的移动会原来的位置
来自: 微社区
这一点确实很好,比系统自带的要好用!  详情 回复 发表于 2019-3-15 13:55
 楼主| 发表于 2019-3-15 11:57:46 来自手机 | 显示全部楼层
如果有,请说明一下,谢谢
来自: 微社区
发表于 2019-3-15 13:08:51 | 显示全部楼层
这个功能比较实用。
发表于 2019-3-15 13:18:48 | 显示全部楼层
回复看看,学习一下
GMT+8, 2026-11-22 09:00 , Processed in 0.306426 second(s), 39 queries , Gzip On, File On.
