查看: 910|回复: 2
[求助]:請問以下 map object arx 的程式碼錯在哪?
发表于 2003-9-4 11:49:11 | 显示全部楼层 |阅读模式
//this function is to attach the object data to the selection which is fit to
// the input layer name
//功能:先取得使用者輸入的圖層名稱,再取得使用者輸入的選集
//當選集中物件是在使用者輸入的圖層時attach the object data
//執行時都能正常運作 但object data不能貼附到物件上
        // ----- asdkmap._addODbyLayer command (do not rename)
static void asdkmap_addODbyLayer(void)
                // Add your code for command asdkmap._addODbyLayer here
                ads_name ss, ename;
                long sslen, sscur;
                AcDbObjectId eId;
                AcDbEntity *pEnt;
                AcMapSession *mapApi = NULL;
                AcMapProject *pProj = NULL;
                AcMapODContainer *pODCont = NULL;
                AcMapODTable *pODTable = NULL;
                mapApi = AcMapGetSession();
                mapApi->GetProject(pProj);
                pProj->GetODContainer(pODCont);
                pODCont->GetODTable(pODTable, "owner");
//                acutPrintf("flag 7\n");
//get input layer 取得 與用者輸入的圖層名稱
                AcDbObjectId inputLayerID;
                char inputLayerName[3];
                if (acedGetString(0,"input filter layer name:",inputLayerName) == Adesk::kFalse){
                        acutPrintf("\nlayer Name is not suitable");
                        return;
                if(checkLayer(inputLayerName) !=Acad::eOk){
                        return;
                getLayerIdFromString(inputLayerName,inputLayerID);
//選取物件
                acutPrintf("\nselect the objects you want to add object data ?");
                if (acedSSGet(NULL, NULL, NULL, NULL, ss) != RTNORM) {
                        acutPrintf("\nNo objects selected.\n");
                        acedSSFree(ss);
                        return;
                acedSSLength(ss, &sslen);
                acutPrintf("flag 6");
//check every entity in the selection and attach the object data, if fit the condition
//檢查每個物件是否在指定圖層上  如果是在指定圖層上 attach object data
                for (sscur = 0; sscur < sslen; sscur++)
                        acedSSName(ss, sscur, ename);
                        acdbGetObjectId(eId, ename);
                        acdbOpenAcDbEntity(pEnt, eId, AcDb::kForRead);
                        char *temp;
                        temp = pEnt->layer();
                        if(*temp == inputLayerName[0]){
                        //        attachODById(eId);
                                AcMapODTableRecord *pTabRec = NULL;
                                pTabRec = new AcMapODTableRecord();
                                pODTable->AddRecord(*pTabRec , eId);
                                acutPrintf("\n object id : %lx", eId);
                                //acutPrintf(\n object id : %lx", targetId);
                                //acutPrintf("\nObject Id %lx",targetId);
                                acutPrintf ("\nOD Record added to object.");
                                if (pTabRec) delete pTabRec;
                                highlightAll(eId);
                        pEnt->close();
                delete pODTable;
        acedSSFree(ss);
//檢查圖層是否存在
static Acad::ErrorStatus
checkLayer(char* layerName)
    AcDbLayerTable *pLayerTbl;
    acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pLayerTbl, AcDb::kForWrite);
    if (!pLayerTbl->has(layerName)) {
                return Acad::eNotApplicable;
    } else {
        pLayerTbl->close();
        acutPrintf("\nlayer already exists");
                return Acad::eOk;
//從輸入的字串取得layerId
getLayerIdFromString(const char* pStr, AcDbObjectId& ID)
    //  Get a pointer to the drawing's layer table
    AcDbLayerTable* pLayerTable;
    Acad::ErrorStatus err = acdbCurDwg()->getLayerTable(pLayerTable,
        AcDb::kForRead);
    if (err != Acad::eOk)
        return err;
    // Get the ID of the layer with the name in 'pStr' (even if it's
    // erased) and place it in 'id'.
    err = pLayerTable->getAt(pStr, ID, Adesk::kTrue);
    pLayerTable->close();
    return err;
已领礼包: 145个
发表于 2003-9-4 12:04:13 | 显示全部楼层
Re: [求助]:請問以下 map object arx 的程式碼錯在哪?
最初由 origo 发布
[B]//the problem is object data can't be attached to the entity
        // ----- asdkmap._ad... [/B]
请你把你的代码的功能、作用,和你调试时候出现的错误提示等等告诉大家,你给够大家足够的信息,最终方便的是你。
发表于 2004-6-24 14:11:50 | 显示全部楼层
1楼楼主说:[求助]:請問以下 map object arx 的程式碼錯在哪?
我现在也要用一些map的开发,但是autocad的类库中并没有包含有一楼楼主提到的那些类!请问我需要安装那些东西?
GMT+8, 2026-11-5 13:51 , Processed in 0.399414 second(s), 36 queries , Gzip On.
