查看: 8144|回复: 56
[下载]:ATable5.6 for CAD2002 程序及汉化包
发表于 2003-11-8 21:12:34 | 显示全部楼层 |阅读模式
ATable 昨天发布了5.6版。5.6版开始有有了CAD2002的版本。这样本软件的一些最新功能又可以在CAD2002中得以应用。本版软件最主要的进步在于提供强大的函数运算功能。该软件支持的函数功能如下:
The reduced list of functions accessible to use in formulas
Function        Description
abs(x)        Returns the absolute value of a number
angtof(string)        Converts a string representing an angle into a real value in radians
angtos(angle)        Converts an angular value in radians into a string
ascii(string)        Returns the conversion of the first character of a string into its ASCII character code
atan(num1, num2)        Returns the arctangent of a number in radians
atof(string)                Converts a string into a real number
atoi(string)                 Converts a string into an integer
boole(operator int1 int2)        Serves as a general bitwise Boolean function
chr(x)                          Converts an integer representing an ASCII character code into a single-character string
cos(x)        Returns the cosine of an angle expressed in radians
distof(string)        Converts a string that represents a real value into a real value
exp(x)        Returns the constant e (a real number) raised to a specified power
expt(x, p)        Returns a number raised to a specified power
fix(x)        Returns the conversion of a real number into the nearest smaller integer
float(x)        Returns the conversion of a number into a real number
gcd(x, y)        Returns the greatest common denominator of two integers
getenv(string)        Returns the string value assigned to a system environment variable
getvar(string)        Retrieves the value of an AutoCAD system variable
handent(handle)        Returns an object (entity) name based on its handle
if        Conditionally evaluates expressions
itoa(x)        Returns the conversion of an integer into a string
log(x)        Returns the natural log of a number as a real number
max(x, y …)        Returns the largest of the numbers given
min(x, y …)        Returns the smallest of the numbers given
rem(x, y)        Divides the first number by the second, and returns the remainder
rtos(x)                 Converts a number into a string
setvar(string, value)        Sets an AutoCAD system variable to a specified value
sin(x)                 Returns the sine of an angle as a real number expressed in radians
sqrt(x)                      Returns the square root of a number as a real number
strcase(string)        Returns a string where all alphabetic characters have been converted to uppercase or lowercase
strcat(str1, str2 …)   Returns a string that is the concatenation of multiple strings
strlen(string)                 Returns an integer that is the number of characters in a string
substr(string, start, length)        Returns a substring of a string
wcmatch(string, pattern)        Performs a wild-card pattern match on a string
可以说,基本上可以在该软件内完成绝大多数的工程计算要求,而不需要事事烦劳EXCEL。
因此,原来在CAD2002环境使用ATable2.5~ATable4.2的用户可以顺利升级到5.6版,享用新版软件的新功能了。
经试验,5.6版的ATable可以使用原来5.0版的注册码进行注册使用。
本版程序适用于CAD2002。
汉化包见附件
 楼主| 发表于 2003-11-9 15:21:07 | 显示全部楼层
为方便网友特提供源文件下载:
1:
 楼主| 发表于 2003-11-9 15:22:06 | 显示全部楼层
2:
 楼主| 发表于 2003-11-9 15:23:04 | 显示全部楼层
3:
 楼主| 发表于 2003-11-9 15:24:05 | 显示全部楼层
4:
发表于 2003-11-9 15:39:45 | 显示全部楼层
最初由 xiaping 发布
[B]为方便网友特提供源文件下载:
[/B]
不是源文件,而是原文件
*-*4
发表于 2003-11-9 17:52:22 | 显示全部楼层
天呀,谁AT5.6的注册码,急盼!
发表于 2003-11-10 12:18:21 | 显示全部楼层
怎么注册?
发表于 2003-11-10 12:31:10 | 显示全部楼层
请教长老:
1、汉化是不是将汉化包里的两个文件拷贝至安装目录,我的怎么不行?
2、安装时好像只能安装在默认目录,选择其他目录安装时会出错;
3、注册码是左罗长老发布的那个吗,我的不行啊,提示注册失败,怎么解决啊?
 楼主| 发表于 2003-11-10 12:58:50 | 显示全部楼层
最初由 大少爷 发布
[B]请教长老:
3、注册码是左罗长老发布的那个吗,我的不行啊,提示注册失败,怎?.. [/B]
1、汉化包了的文件解压后覆盖安装即可。但是要注意一定要找到原文件安装的地方进行同名覆盖。因为两个文件的路径时不一样的。另外,覆盖安装以后初次进入界面以后还需要在工具菜单里面将语言选项设置为简体中文。退出后重新加载才能成为中文界面。
2、该软件是可以自定义安装的。
3、佐罗增经发布过3个注册码,其中两个是在没有CAD2004的情况下推测的经实验是不能使用的。帖子里面有回复无法注册的是不能用的。
发表于 2003-11-10 13:16:49 | 显示全部楼层
汉化菜单出来了,谢谢长老指点。
我只找到佐罗长老发布的两个注册码,这里:
http://www.xdcad.net/forum/showthread.php?s=&threadid=80518
还得请长老你指点迷津,还有一个在哪里?请你给个连接好吗?谢谢!
发表于 2003-11-10 13:25:35 | 显示全部楼层
还有一个问题请教:
 楼主| 发表于 2003-11-10 16:17:27 | 显示全部楼层
最初由 大少爷 发布
[B]还有一个问题请教: [/B]
你所指的是文字助手。安装目录下有一个Assistus.txt文件。其内容是俄文的,所以显示为乱码。你可以将里面的内容删除,重新用中文写入你需要的文字即可成为中文。
发表于 2003-11-10 20:10:47 | 显示全部楼层
看到了长老做的文字助手讲座演示,真是好极了!
您能不能将您修改的Assistus.txt文件提供下载,好让大家参考一下书写格式?
 楼主| 发表于 2003-11-10 20:28:41 | 显示全部楼层
最初由 大少爷 发布
[B]汉化菜单出来了,谢谢长老指点。
还得请长老你指点迷津,还有一个在哪里?请你给个连接... [/B]
你在精华版里面找,应该是一个注册表文件。只要导入注册表就完成注册了。
GMT+8, 2026-11-22 09:13 , Processed in 0.445859 second(s), 38 queries , Gzip On, File On.
