查看: 1749|回复: 0
[求助]:如何在AutoCAD多文档切换之间自动加载自定义的PGP
发表于 2008-5-23 21:54:59 | 显示全部楼层 |阅读模式
下面是一个自定义的Aunger.PGP文件加载程序,但是存在一个问题:
发现当第一次打开autocad文件时,会自动加载Aunger.PGP中自定义的命令,但是当多文档之间切换时,则丢失了,只能手动运行一次ayCMD命令,很麻烦的,请高手赐教!谢谢
(defun C:ayCMD(/ PGPFile fp i xString aList shortCMD GlobalCMD)
(vl-load-com)
(setq PGPFile "Ayunger.pgp");F:\\Ayungerstudio\\VLisp\\Ayunger.pgp
(if (setq PGPFile (findfile PGPFile))
(progn;then
(setq fp (open PGPFile "r"))
(setq i 1)
(while (setq xString (read-line fp))
(if (= (type xString) 'SYM) (setq xString (vl-symbol-name xString)));转换数据文件中无引号的字符串.
(while (vl-string-search " " xstring);去掉所有的空格.
(setq xString(vl-string-subst "" " " xstring));空格.
(setq xString(vl-string-subst "" " " xstring));tab符.
);end_while
(if (and (/= (substr xString 1 1) ";") (vl-string-search "," xstring) (vl-string-search "*" xstring))
(progn
(setq aList (read (strcat "(" (vl-string-subst " . C:" ",*" xString) ")")))
(setq shortCMD (vl-string-trim " " (vl-symbol-name (car aList))))
(setq GlobalCMD (cdr aList))
;(vlax-remove-cmd shortCMD);删除已定义的命令.
(vlax-add-cmd shortCMD GlobalCMD)
);end_progn
);end_if
(setq i (+ i 1))
);end_while read-line
(close fp)
);end_progn then
(princ "\nAY工具简化命令定义文件 Ayunger.pgp 没找到或不存在!")
);end_if
(princ)
);end_defun
;;Ayunger.PGP
;; AY工具命令简化设置文件
;; Copyright Ayunger Studio 2001-2008
;; E-mail: AyungerStudio@163.com
;; 格式: <简化命令>, *<完全命令>
ARW, *ayArw
TL, *ayRailway
SPX, *aySpx
ZPX, *ayZpx
PDX, *ayPdx
PDXC, *ayPdxC
CX, *ayPerCurve
QX, *ayTanCurve
LL, *ayLL
GMT+8, 2026-11-22 08:19 , Processed in 0.267867 second(s), 10 queries , Gzip On, File On.
