查看: 667|回复: 0
[推荐]:得到*.slb所有幻灯片名称:
已领礼包: 488个
发表于 2003-11-9 13:55:13 | 显示全部楼层 |阅读模式
这是我用vb.net写的,才学几天,大家多关照:
我把幻灯的地址也放进去了,省的又再找一遍.
  1. Function tohex(ByVal address() As Byte) As String
  2.         Dim i As Integer = 3, a As String = "", b As String
  3.         For i = 3 To 0 Step -1
  4.             b = Hex(address(i))
  5.             If (Len(b)) < 2 Then
  6.                 b = "0" + b
  7.             End If
  8.             a = a + b
  9.         Next i
  10.         tohex = "&H" + a
  11.     End Function
  12. Function getallname(ByVal file As String, ByRef all() As String, ByRef all_add() As String) As String()
  13.         Dim i As Integer, name(31), add(3) As Byte
  14.         Dim allname(0), a, address(0) As String
  15.         Dim fs As FileStream = New FileStream(file, FileMode.Open, FileAccess.Read)
  16.         Dim r As New BinaryReader(fs)
  17.         name = r.ReadBytes(32)
  18.         While name(0) <> 0
  19.             a = ""
  20.             i = 0
  21.             name = r.ReadBytes(32)
  22.             add = r.ReadBytes(4)
  23.             While name(i) <> 0
  24.                 a = a + (Chr(name(i)))
  25.                 i += 1
  26.             End While
  27.             If a <> "" Then
  28.                 allname(allname.Length - 1) = a
  29.                 ReDim Preserve allname(allname.Length)
  30.                 address(address.Length - 1) = (tohex(add))
  31.                 ReDim Preserve address(address.Length)
  32.             End If
  33.         End While
  34.         fs.Close()
  35.         all = allname
  36.         all_add = address
  37.         Return allname
  38.     End Function
这是vb写的.
  1. Public Function ReadSLBNames(strFile As String) As Variant
  2.   Dim lngFile As Long
  3.   Dim strTemp As String
  4.   Dim lngCnt As Long
  5.   Dim strVals() As String
  6.   Dim varRet As Variant
  7.   Dim intcnt As Integer
  8.   On Error GoTo Err_Control
  9.   lngFile = FreeFile()
  10.   lngCnt = 33
  11.   Open strFile For Binary As #lngFile
  12.   Do While Not EOF(1)
  13.     Seek lngFile, lngCnt
  14.     Line Input #lngFile, strTemp
  15.     If Not strTemp = vbNullString Then
  16.       ReDim Preserve strVals(intcnt)
  17.       strVals(intcnt) = strTemp
  18.       intcnt = intcnt + 1
  19.       lngCnt = lngCnt + 36
  20.     Else
  21.       Exit Do
  22.     End If
  23.   Loop
  24.   Close lngFile
  25.   varRet = strVals
  26.   ReadSLBNames = varRet
  27. Exit_Here:
  28.   Exit Function
  29. Err_Control:
  30.   Select Case Err.Number
  31.   'Add additional Case selections here
  32.     Case Else
  33.     MsgBox Err.Description
  34.     Err.Clear
  35.     Resume Exit_Here
  36.   End Select
  37. End Function
GMT+8, 2026-11-2 21:58 , Processed in 0.420773 second(s), 32 queries , Gzip On.
