查看: 3396|回复: 4
[原创]:AutoCAD Electrical 2004 (C) Autodesk
发表于 2003-11-25 16:01:25 | 显示全部楼层 |阅读模式
AutoCAD  Electrical software gives you fast control schematics design
      capabilities,  automatic wire numbering and component tagging, and an
      intelligent  control  panel utility to help you work more efficiently
      and significantly reduce design errors. For drawing sets with PLC/IO,
      motor  control,  or  discrete  electrical control components, AutoCAD
      Electrical  makes  your  cycle time shorter, your engineering changes
      faster,  and  your  design quality better. Easy to learn and use, and
      built  on  the  AutoCAD platform with full DWG compatibility, AutoCAD
      Electrical  is  the  single  best  software for faster, more accurate
      electrical controls design and engineering.
      For more information:
      http://www.autodesk.com
      Unpack and Burn, look into /crack folder for install info.
      Enjoy this fine release from TEAM ROR :)
发表于 2003-11-26 08:59:50 | 显示全部楼层
Electrical 部份是外挂的,谁能把它提取出来,加入中文CAD2004中
发表于 2014-12-26 09:24:23 | 显示全部楼层
不错,挺好的,谢谢!
发表于 2024-1-1 08:57:17 | 显示全部楼层
谢谢分享!!!!!
GMT+8, 2026-11-22 07:55 , Processed in 0.554096 second(s), 16 queries , Gzip On, File On.
