查看: 723|回复: 0
[求助]:内存的问题
发表于 2003-12-25 12:05:35 | 显示全部楼层 |阅读模式
Acad::ErrorStatus domProfileInput1()
      ads_name ssName;  //the name of selection
      struct resbuf eb1/*, eb2, eb3*/;
      char sbuf1[10]/*, sbuf2[10]*/; // Buffers to hold strings
      eb1.restype = 0; // Entity type group
      strcpy(sbuf1, "LINE");
      eb1.resval.rstring = sbuf1; // Entity type is line.
      eb1.rbnext = NULL;
      if((acedSSGet(NULL, NULL, NULL, &eb1, ssName))!=RTNORM)// Retrieve all line.
            return Acad::eInvalidInput;
         //note add error check
      long length;
      AcDbObjectId objId;
      AcDbEntity* pEntity;
      acedSSLength(ssName, &length); //Returns the length of  selection
      //////////////显示进度条///////////////////////
      acedSetStatusBarProgressMeter("正在写入数据,请稍候...", 0, length);//显示一个length长度的进度条
           for (int i = 0; i < length; i++)
                      ads_name ent;
                      acedSSName(ssName, i, ent);
                        //Returns the name of an entity in a selection set by index
                      acdbGetObjectId(objId, ent);//get ObjectId by ads_name
                     acdbOpenObject(pEntity, objId, AcDb::kForWrite);
                     addXdata1( pEntity) ;//add xdate to pEntity(一个加扩展数据的子程序,没贴出)
                     AcGePoint3d startpnt ,endpnt;
                     ReturnEntInfo(ent, startpnt, endpnt);
                        //acutPrintf("MaxBox[X] is %f ", startpnt[X]);//print
                            //下面的AcGePoint3d与ads_point觉得有点机械,有没有好的方法?(函数积累不够)
                                ads_point pt1,pt2;
                                pt1[X]=startpnt[X];
                                pt1[Y]=startpnt[Y];
                                pt2[X]=endpnt[X];
                                pt2[Y]=endpnt[Y];
                                ads_real angle=acutAngle(pt1,pt2);
                                ads_point a1, a2, a3, a4;
                                acutPolar(pt1,(angle+PI/2),150.0,a1 );
                                 acutPolar(pt1,(angle-PI/2),150.0,a4 );
                                 acutPolar(pt2,(angle+PI/2),150.0,a2 );
                                 acutPolar(pt2,(angle-PI/2),150.0,a3 );
                                 AcGePoint3dArray vertices;
                                 AcDb2dPolyline *pNewPline;
                                 vertices.append(asPnt3d(a1));
                                 vertices.append(asPnt3d(a2));
                                 vertices.append(asPnt3d(a3));
                                 vertices.append(asPnt3d(a4));
                                //vertices.append(asPnt3d(a1));
                        pNewPline=new   AcDb2dPolyline(AcDb::k2dSimplePoly,vertices,0,Adesk::kTrue,/*Width*/0,/*Width*/0);
                        // else pNewPline=new AcDb2dPolyline(AcDb::k2dSimplePoly,vertices,0,Adesk::kFalse,Width,Width);
                                 AcDbObjectId id;
                                 postToDatabase(pNewPline, id);//
            pEntity->close();
       acedSetStatusBarProgressMeterPos(i);//根据i来显示进度情况
           acedSSFree(ssName); //release ssname
       acedUpdateDisplay();//update Display
        //////////////消毁进度条/////////////////////////
            Sleep(5);//产生5秒钟的停滞
            acedRestoreStatusBar();//消毁进度条
           //acDocManager->unlockDocument(curDoc());
       //acedPostCommandPrompt();
           return Acad::eOk;
//下面的取得LINE的起点,终点函数老觉得不好。由于初学, 函数积累不够,我没找到其他方法。
int ReturnEntInfo(ads_name entity, AcGePoint3d  &startpoint , AcGePoint3d  &endpoint)
        struct resbuf *rbEnt;
        struct resbuf *rbTrav;
        rbEnt = acdbEntGet(entity);
     acedSSFree(ssName);
        if(!rbEnt)
                acutPrintf("\nFailed to get entities result buffer linked list. ");
                return 0;
   rbTrav = rbEnt;
        while(rbTrav)
                switch(rbTrav->restype)
                                case 10 :        // startpoint
                                startpoint[X]=rbTrav->resval.rpoint[X];
                startpoint[Y]=rbTrav->resval.rpoint[Y];
                                startpoint[Z]=rbTrav->resval.rpoint[Z];
                        break;
                        case 11 :        // endpoint
                                endpoint[X]=rbTrav->resval.rpoint[X];
                                endpoint[Y]=rbTrav->resval.rpoint[Y];
                                endpoint[Z]=rbTrav->resval.rpoint[Z];
                        break;
                        default :
                                break;
                } // switch
                rbTrav = rbTrav->rbnext;
        } // while
        if(rbEnt)
                acutRelRb(rbEnt);
上面程序实现:通过选择直线,添加扩展数据。然后根据扩展数据以直线为中心绘一框形多义线(本例中我直接取150),
功能实现了。但如果选择直线较多,我看内存就慢慢的上升。找了好久也没解决。
各位帮忙看看,同时对程序的书写给点意见。
GMT+8, 2026-11-4 01:51 , Processed in 0.474323 second(s), 32 queries , Gzip On.
