查看: 649|回复: 2
[LISP函数]:请指示
发表于 2004-2-2 20:45:29 | 显示全部楼层 |阅读模式
(defun *error*(st)
  (princ (strcat "Error: " st))
  (princ)
(defun C:chh(/ test ss len n en1 a oldr newr ent nn)
  (setvar "CMDECHO" 0)
  (setq test T nn 0)
  (while test
    (setq ss (ssadd))
    (setq ss (ssget))
    (if (= nil ss)
      (setq test nil)
      (progn
        (setq len (sslength ss))
        (setq n 1 s 1)
        (while (<= n len)
          (setq en1 (ssname ss (1- n)))
          (setq a (entget en1))
          (if  (= "TEXT" (cdr (assoc 0 a)))
            (progn
              (if (= s 1)
                (progn
                  (setq oldr (cdr (assoc 40 a)))
                  (setq newr (getreal (strcat "\nNew high <" (rtos oldr 2 1) ">:")))
                  (if (= newr nil) (setq newr oldr))
                  (setq s nil)
              (setq ent (subst (cons 40 newr) (assoc 40 a) a))
              (entmod ent)
              (setq nn (1+ nn))
          (setq n (1+ n))
  (princ (strcat (itoa nn) " changed !"))
  (princ)
请问有谁可以指点一下,这个文件怎么用,说是改变文字高度的,可是我加载这个文件后就是不能用,不知道是怎么回事!
发表于 2004-2-3 18:32:54 | 显示全部楼层
这个程序的确可以修改文字高度,但它只能修改单行文本,不能修改多行文字。因为下面这段语句:(if (= "TEXT" (cdr (assoc 0 a)))它过滤了非“TEXT”对象,所以它只能处理“TEXT”对象,不能处理非“TEXT”对象。
发表于 2004-2-4 11:46:45 | 显示全部楼层
将(if (= "TEXT" (cdr (assoc 0 a)))
改成:(if (or (= "TEXT" (cdr (assoc 0 a))(= "MTEXT" (cdr (assoc 0 a))))
就可以对Mtext有效了。
GMT+8, 2026-11-5 04:08 , Processed in 0.518281 second(s), 36 queries , Gzip On.
