查看: 889|回复: 1
[LISP函数]:看这双向offset程序
发表于 2004-4-4 20:43:33 | 显示全部楼层 |阅读模式
看看这个程序好不好用。
(defun c:text(/ a b b1 p1 d pckbox)
(setq d 20 p1 nil pee (/ pi 2)e 3 pckbox (getvar "pickbox")line " ")
(if(= #parof nil)(setq #parof(/(getvar "viewsize")10)))
(princ "\n当前偏移量 <")(princ #parof)
(setq answer(getstring ">: "))
(if (/= (atof answer) 0.0)(setq #parof(atof answer)))
        (princ line)
        (setq ent(entsel "\n拾取线: "))
        (setq point(cadr ent))
        (princ line)
        (setq side(getpoint "\n拾取要偏移的一方: "))
        (setq dist(distance side point))(setq ang(angle side point))
        (if(or(or(< ang 0.78)(> ang 5.5))(and(> ang 2.35)(< ang 3.92)))
                (setq ang(- 0 ang))(setq ang(- pi ang))
        );end if
        (setq other(polar point ang dist))
        (command "offset" #parof ent side ent other "")
        (entdel(car ent))
(princ)
(princ)
已领礼包: 488个
发表于 2004-4-4 21:07:44 | 显示全部楼层
既然是双向offset,还要"要偏移的一方"干什么.
GMT+8, 2026-11-4 18:58 , Processed in 0.621834 second(s), 34 queries , Gzip On.
