查看: 1355|回复: 0
[试用]:将中文数字转化为阿拉伯数字
发表于 2002-11-13 16:03:10 | 显示全部楼层 |阅读模式
将中文数字转化为阿拉伯数字(只可以处理小于十万的数字)
;;一般我只用它来处理图框的中英文数字加减,
;;谁有兴趣做个范围更大的?
  1. (defun cn2arab-dd (  string / arabia-cnlst-dd i n sstr kstr knum snum num )
  2. (setq arabia-cnlst-dd '((  "零" . 0)  ("一" . 1 ) ( "二" . 2) ( "三" . 3) ( "四" . 4) ( "五" . 5 )   ( "六" . 6 )  ( "七" . 7) ("八" . 8) ("九" . 9) ( "十" . 10) ("百" . 100) ( "千" . 1000)  ("万" . 10000))
  3. )
  4. (if (= "十" (substr string 1 2)) (setq string (strcat "一" string)))
  5. (setq num 0)
  6. (setq i 1)
  7. (setq kstr "零")
  8. (setq n (1+ (/ (strlen string) 4)))
  9. (while (/= kstr "")
  10.   (setq sstr (substr string i 2))
  11. (if (/= "" sstr) (setq snum (cdr (assoc sstr arabia-cnlst-dd))) (setq snum 0))
  12.   (setq kstr (substr string (+ i 2) 2))
  13. (if (/= "" kstr) (setq knum (cdr (assoc kstr arabia-cnlst-dd))) (setq knum 1))
  14. (if  (= sstr "零")
  15.      (if (= "十" kstr) (setq num (+ num  knum)) (setq  i (-  i 2 )))
  16.      (setq num (+ num (* snum knum)))
  17.   )
  18. (setq i (+ 4 i ))
  19. )
  20. num
  21. )
  22. ;
GMT+8, 2026-11-3 06:01 , Processed in 0.444497 second(s), 32 queries , Gzip On.
